Why don't you try these guys if your local dealer doesn't carry it? |
http://www.camaro5.com/forums/showpo...&postcount=164 |
Can't your passenger just write the information on the windshield for you. :iono:
That way you would not have to look down, just over a little bit? I'm just saying.:w00t: Dry erase markers are pretty cheap............:confused0068: |
You MANIAC!
Can't get a straight answer out of Mr 2SSRS. |
Go 'test drive' a '11 with HUD and BORROW what you need.
I like your thinking, But its called grand theft auto.LOL If the dealer had a 2011 I may test it But they did not order any so far.(It may be that Charging 10K over on the car lost them some costumers.):sm0:
You think GM would offer a retrofit kit. :thumbdown:
if gm would make a retrofit it would cost thousands cause they would offer the glass, the dash and everything else, when ofer makes the kit its only what you truly need, the switch, the harness and the hud unit
just drove a 2011 with hud,, and it is awsome,, if you get the conversion figured out ill probly be doing it to mine!
I traded my 10 in for an 11 2ss/rs and thehud gets more and more awesome daily.... If I had kept the 10 then there is no way i would want to be without it. Once you get it working, you will be so psyched!
