DIY: How to EASILY place LONG DETAILED instructions in your DIY.
2 Attachment(s)
Not long ago I built a VERY detailed DIY. It took me a long time to get it just right and take all the pictures and insert them into the document. I built it in WORD. I don't have ACROBAT. After I was done, I realized how large the file was, it was 28 meg (LOTS of large pictures), and was 24 pages long, WOW and our site only allows a MAX size of 585.9 KB for word files. OH CRAP! then I remembered I had a FREE ON-LINE Word to Acrobat file converter! This works like a CHAMP! and we are allowed up to 2.77 megs for Acrobat files.
After I converted my 28 meg word file, it ended up being a 682 KB Acrobat file. SO, if you have built a long/detailed DIY or plan on building one, think about it, it would be VERY handy to be able to print it out for use when doing the MOD/INSTALL. So first build your DIY in word, then convert it to acrobat and save it. Then just start off your DIY with a short discription of your DIY instructions and attach your instructions in the form of the Acrobat file you just converted. and HERES HOW TO DO IT! After you build your word file and save it onto your computer, go to the http://www.doc2pdf.net/ site. At the bottom of the page you will find a BLUE box where you will find the "CONVERT THIS DOCUMENT" and "BROWSE" boxes. Find your file and select it, then simply hit the "CONVERT DOCUMENT" button. Attachment 275954 in a matter if SECONDS a "FILE DOWNLOAD" box will pop up where you can save your new converted file to your computer. Attachment 275948 DONE!! Hope this helps and will give you the ability to put some long/detained instructions here that you can print out for use during your install. AND ALWAYS keep a copy of the original WORD file, so if you need or want to edit it for some reason, you can. Then you repeat the process, make a new version, and upload and replace the original. PIECE OF CAKE!! |
If anyone has any questions.....feel free to post them up or send me a PM.
For all of you that don't know, you can create a .pdf file for free. The program is called CutePDF. It is a free download call CutePDF Writer that basically installs a printer called "CutePDF", you select that printer when printing your document and it will come up and ask you where you wish to save your document and it will be saved as a .pdf. You can visit their website HERE.
Hope this helps !! |
Good stuff
Good stuff - will come in handy for many.Thanks for sharing.
+1 for CutePDF
Been using it for along time, it's a great addon for any PC |
Damn! I wish I had read this thread before I just spent 3hrs doing the same thing you did. Story of my life :thanks:
you can also use a free pdf creator called PrimoPDF.
web site is same as its name, or google it. totally free. I use Primo over Cute, if I am 'printing' a detailed cad drawing to email or one that needs to be printed very large, like 4' x 6'. the Cads own PDF writer, and Cute both will sometimes create a PDF that has some 'blank' areas for no reason...its like trying to print out something so hugh that you run out of ram and it prints blanks randomly on paper....so PrimoPDF is great for creating very large jobs from any application. if it can handle 1 million sq ft warehouse cad blueprints, it can handle DIY's! :) |
Or you can right click - in the MS Word menu, select save as - then select PDF. No need for any other programs.
How about a place to HOST .PDF files so you can get them to people who need
them? https://www.keepandshare.com |
