Will 20x10 +35 Offset Fit
I am looking to pick up some new wheels. Will the 20x10 +35 fit on the front and rear? I want to go with a squared stance with the ability to rotate my tires.
Will be using my oem wheels to get some drag radials for the track. |
Yes. That is the same set up I have on mine now with Factory Reproduction wheels and Nitto INVO tires. Might be getting coilovers next to lower a bit.
If you have coilovers it may or may not fit. If you have stock struts and no plans to get coilovers then you are good to go depending on the wheel. As it may or may not clear the brakes.
will depend on the wheel u choose. I had to go with a 20mm offset cause the spokes would hit the calipers going larger offset. I had to choose, either stay with that offset or put my v6 calipers back on.
I've got 20x10.5 front and rear on bags . They will fit. Lol.
I talked to the manufacture and the +23 won't fit on the front. So I decided to go with the factory reproduction stain black 20x10 +23 for all 4 so I can rotate my tires and get more life out of them.
1 Attachment(s)
Here's my FR 20x10 +35 squared set up. +35 will fit up front.
1 Attachment(s)
3 Attachment(s)
Here are a few different angles I have. Car is lowered 1 inch in these pix. Tire size is 275/40/20 in front and 315/35/20 in back.
Attachment 654251 Attachment 654252 Attachment 654253 |
1 Attachment(s)
20x10.5 +35 All around.
This thread was a god send btw.... Helped me decide. Order may be going in today
My 315 set up actually hits in the rear on big bumps at speed just barely but I'm lowered 1 inch
@chris14rs bagged... wow!
