04-01-2016, 10:20 PM | #183 |
Drives: 2011 L99 SS Join Date: Oct 2014
Thanks.
If I only had the amp mount plate now. i think I've got it now... |
04-02-2016, 10:12 AM | #184 |
No power to the amp.
04-03-2016, 03:35 AM | #185 |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
04-03-2016, 11:42 AM | #186 |
Just finished my modest AMP/10inSUB using the sthump harness. It absolutely makes the stock BA sound better.
2013 ZL1
Tint, wheels, Michelin PSS, Kook LT headers, HF cats, 1050injectors, 5% pulley, Mcleod 1000hp clutch, 160 thermostat, spark plugs and cables, Eibach springs, hurst shifter, CAI, Anderson carbon hood, carbon rockers, front and rear carbon valence, carbon spoiler, Oracle side markers and side mirrors, stainless door kicks, carbon strut tower brace, carbon supercharger cover, southern car parts engine bay kit, seperate clutch reservoir, kenwood DDX990 4s with appple car play. |
05-17-2018, 02:36 PM | #187 |
Drives: 2011 SS2 Camaro IBM Join Date: May 2018
Guys, I have a 2011 with the BA. Could someone please post the link to the wiring harness i need for the Rockford Fosgate 10 in sub?
05-17-2018, 02:37 PM | #188 | |
Installed Rockford Fosgate powered subwoofer
http://********.com/Chevrolet-GMC-Cu...-Channels.html Replace the **** with the letters “sub thump” no space |
05-21-2018, 11:20 AM | #189 |
I installed a 10" on my Camaro this weekend. Just a little confused on the Power connections. I used 10 AWG wire and a 5 amp inline fuse. I think I need to beef up the fuse. What did you guys use?
Thanks |
05-21-2018, 11:27 AM | #190 |
Did you use an inline fuse on the Positive battery connection and if so what size?
05-21-2018, 08:39 PM | #191 | |
Depends on the amplifier needs, 10 gauge wire carry around 30 amps or an amplifier that produces 100-200 watts.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
05-21-2018, 08:56 PM | #192 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
Are you sure you have the switch for the amp turn on set correctly?
Thread Tools | |
