01-28-2018, 11:57 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Aug 2017
2016 SS A8 rough 1-2 shift?
I bought a used 2016 SS with the automatic a few weeks ago. Largely happy with it, just one thing that's been bugging me a bit.
When I'm driving it sedately, in "tour" (which has been a lot lately with the crappy weather) I've noticed that the 1-2 shift can be a bit rough and jerky. The other shifts are fine, and if I'm giving it a good amount of gas, 1-2 is fine, it's just if I'm accelerating slowly that it's jerky. Is this just the way the transmission is, or is it something that should be looked at?
Current stable:
2019 Camaro 2SS (same as 2016 but 10AT) 2014 Subaru WRX (Satin White Pearl, Kenwood Carplay headunit) Past stable: 2016 Camaro 2SS (8AT, NPP Dual Mode Exhaust, Magride, sunroof, Summit White, black metallic center stripe, Adrenaline Red interior trim) 1990 Mazda Miata (too many mods to list) 1988 Mazda 323 Wagon (With 323 GTX motor!) 1987 Monte Carlo SS (Grey on grey, gunmetal-grey painted GTA wheels, lowered, dual exhaust, and much more) 2006 Subaru Impreza 1981 G20 Van (3-tone brown, shag/velvet interior) |
01-29-2018, 12:39 AM | #2 | |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
It’s pretty common with the A8. I could be wrong but I believe it is because of the AFM. |
01-29-2018, 06:21 AM | #3 |
Drives: 18 zl1 Join Date: Aug 2017
mine does this on occasion, but usually because it hasn't warmed to operating temperature yet. I've not noticed it when its had enough time to warm up.
01-29-2018, 07:17 AM | #4 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
01-29-2018, 07:43 AM | #5 |
Mine does it too. It’s just a really hard 1-2 shift, that seems out of place when driving conservatively. But I’ve noticed it after sufficient warm-up time too!
01-29-2018, 08:38 AM | #6 |
Drives: 2016 NFG SS A8 Join Date: Jul 2014
Good luck getting GM to do anything about it. It is a common complaint on this transmission. Mine does it on the first shift of the morning and in the summer when the trans temp gets up to 150, it will do it everytime while you are driving lightly. If you get stuck in stop and go traffic while its doing this, it will drive you insane. I even switched to the new recommended GM/mobile one transmission fluid and it made ZERO difference. This A8 trans is horrible in anything but all out acceleration.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
01-29-2018, 09:04 AM | #7 | |
Drives: 2019 ZL-1 Join Date: Feb 2009
Wrong- Not the AFM.... it needs a fluid flush and trans reprogram.
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
01-29-2018, 09:48 AM | #8 |
Ive had 3 flushes, torque converter changed, fluid changed to the new GM Dexron HP and reprogramed. Its still the same. Just waiting until I get the car paid down a little more and this sucker is outta here. No more Camaros for me unless the refresh has the A10 and even then ill wait to see what issues people have. GM screwed the pooch on the A8. Great idea that was poorly executed
01-29-2018, 09:50 AM | #9 |
Drives: 2017 50th Anniversary Join Date: Dec 2015
Mine does this on the first couple of shifts in the morning. Let the dealer know the next time you take it in. They will reprogram the trans and more than likely flush the fluid.
01-29-2018, 11:29 AM | #10 |
Thanks for the info folks.
Mine is doing it warm or cold, doesn't seem to matter. I'll mention it next time it's at the dealer, see if they can do anything. If not, no biggie. Mine's not bad enough to put me off the car, just mildly annoying.
Current stable:
01-29-2018, 11:42 AM | #11 |
Drives: 2016 2SS Camaro Join Date: Feb 2016
Mine does it only cold, first shift leaving in the morning
2SS - Summit White - MRC - NPP
01-29-2018, 11:43 AM | #12 |
I've never had much luck with GM automatic transmissions. I should have known. I have the rough 1-2 shift when cold and it feels like the torque converter lockout is cutting in and out at about 45 mph when trans is warmed up. Loved my M6 in my Corvette. Should have saved the extra money and got the manual.
01-29-2018, 12:05 PM | #13 | |
Drives: 2014 c7 corvette and 2017 camaro ss Join Date: Jun 2017
might be picking up the new alfa romeo giulia quadrifoglio or a audi rs3 |
01-29-2018, 12:52 PM | #14 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
FOR ALL THOSE EXPERIENCING THIS ISSUE:
HERE IS THE FIX: While its not exactly a PROBLEM persee, GM is aware of this issue and there IS a fix for it... There is actually TSP issue related to the TCM. I was experiencing this and took it in and they re-calibrated my TCM and the issue went away. It hasn't been doing it since... Here...read my thread and at the very end you will see the solution: http://www.camaro6.com/forums/showthread.php?t=518185 |
Thread Tools | |
