07-06-2022, 07:52 AM | #1 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Alignment
Hey there guys,
I have a 2013 SS to which I've fitted a set of ZL1 replica rims (from MMR) I fitted new Pirelli P-Zero tyres at the same time. Both rear tyres are heavily worn on the inside after only 5k miles; I do drive her "enthusiastically" most of the time but don't do burnouts etc so I'm surprised they haven't lasted longer. A few owners tell me I should get the car aligned in a shop to ZL1 spec to ensure better wear. Any thoughts? And has anyone on here got alignment specs they can share? Over here in the UK tyre/alignment places are not generally conversant with Chevrolet gear. Thanks in advance for any help given. Ed
07-06-2022, 08:17 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I use the aggressive street found here;
https://www.camaro5.com/forums/showp...52&postcount=2 Note that there are typos in the OEM columns so don't use those without confirming. |
07-06-2022, 09:13 AM | #3 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
I just installed new 1LE wheels and Michelin PS4s and replaced my front coilovers. Going in Friday to have it aligned to the ZL1 spec. I can forward you the GM specs for all Camaros I had from years ago. I've had many different alignments done over the years when I tracked my car. Going back to the street friendly settings that are OEM since I don't track anymore. $2000 bucks for PS4s I want then to last.
07-06-2022, 11:35 AM | #4 |
Here's the OEM specs I had.
07-06-2022, 02:19 PM | #5 |
Awesome stuff. Cheers guys.
07-06-2022, 04:03 PM | #6 |
Same here, when I lowered my Camaro and went with the wider wheels, and offsets, I had them install a ZL1 alignment spec to the suspension, front and back, as the stock SS wheels were pretty narrow, and the aftermarket wheels much wider and moved outward a bit more. No issues with tire wear front of back after 11 years!!
07-07-2022, 07:53 AM | #7 | |
07-07-2022, 06:28 PM | #8 |
You are welcome. Good luck... I run a 285/35 front tire on a 10.5 wide wheel in the front and a 335/30 tire on a 11.5 wide wheel on the rear. Previous wheels were the MMR -M228 Z28 replica's, 20x10 +23 front with 275/35 tire and 20x11 rear +43 with 315/35 tire.
07-08-2022, 03:12 AM | #9 | |
07-08-2022, 08:09 AM | #10 | |
335's on the 11.0 wide M228's.
Thread Tools | |
