09-28-2023, 04:33 PM | #127 | |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
What class are you running?
10-01-2023, 11:17 PM | #128 | |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
10-02-2023, 06:13 AM | #129 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Interested in your thoughts and experience with the driveshaft. I just installed one on my 1LE recently but the car is down for other services right now and I haven't driven with it yet.
10-03-2023, 08:16 AM | #130 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
Pricing for their products is right on the website. Check out they have options for you. If you need something custom give them a call.
Holley Terminator X Max Single Turbo 6SPD Manual 1LE DSMLIGHTS TUNED
10-03-2023, 08:26 AM | #131 | |
Quality is far superior that what you see from the typical aftermarket options. The customer service has been fantastic! Tight, Perfect Fit upon install. This was all done while car was on jack stands in the garage. Have only backed it out and moved it to allow for one of our other cars to be brought in due to terrible weather over the last 10 days here in SOFLO. Hopefully tonight after a plug wire swap we can test it out. Will certainly follow this up so stay tuned!
04-25-2024, 10:27 AM | #132 |
Quick Update, Driveshaft 0 issues so far. 4-digit power. Also, we have removed all of the fiberglass wrap and have coated everything. After hitting the rollers last nightie can certainly say the coatings put in work. Engine Bay temps are way down and the best part about it the ability to shorty after touch and work on if need be. I would highly recommend the coatings vs the fiberglass 10/10.
