03-12-2019, 12:35 PM | #155 |
SS
just read this ,Wow a solution via GM! called in but probably not covered under warranty (I still have extended warrant) even though i have service records showing the complaint while under limited warranty, waiting on the call back....
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
03-21-2019, 04:32 PM | #156 |
SS
not covered under my power train but, asking GM if the note on file about the issue at 9000 is good for it...
03-21-2019, 04:44 PM | #157 |
if they say no. press them they have to honor it. because the problem was under warrenty. they know anyways they have issues with it anyway. hold your ground. some dealers will say know until you challenge them.
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
03-21-2019, 09:33 PM | #158 |
SS
will do , they got notes on file ! as long as they don't try the tune card , thanks
03-22-2019, 09:32 PM | #159 |
SS
its under review , after reminding her again, we now also have a 2017ile from them and also that the forum said push for it so i did..., smarter decisions hopefully from GM uppers
03-23-2019, 08:14 AM | #160 |
Drives: 2010 2SS/RS Join Date: Dec 2009
So what was a 500 dollar part is now approximately 150'ish....
Orange Krush II
03-23-2019, 07:23 PM | #161 |
SS
nice to know or there's the spring install that was 30.00 and a drill
08-12-2019, 07:02 AM | #162 |
This just happened to me yesterday on my 2010 camaro ss. Doing a test launch and my clutch pedal stuck to the floor.. I had to press it a couple times for it to release. I could smell my clutch afterwards. The car is shifting fine and the pedal seems to be ok. After seeing this thread... I think I need to dig into this. What do you guys/gals suggest?
08-12-2019, 08:53 AM | #163 |
GM Parts Direct 140 bucks. Wonder how this will work with a new Monster LT-1 clutch
Orange Krush II
08-12-2019, 10:16 AM | #164 | |
Drives: 2015 2ss Join Date: Jun 2009
i'd also check the color of your brake fluid, it's probably toast. a brake fluid flush is probably in your near future (since it's also shared with the clutch hydraulics)
2015 Camaro 2ss, NicKey Performance built/tuned |
04-12-2022, 09:45 AM | #165 |
Guys,
I’m very late to the party on this one so please bare with me. I’ve had my car for about 3 years and never tried to do a burn out just because I didn’t want to waste the tires. I went to a drag and drive last weekend and tried to do one. When I tried to do it I dumped the clutch and the clutch pedal started moving up and down on its own. At the car did nothing, is that what this recall is about. I bought the car in 18 so I’m not sure if this correction has been completed or not. Thanks for your help |
04-13-2022, 07:46 AM | #166 |
There is NO recall on this, only a TSB and TSBs are only required to be covered during the warranty period.
You can take it to a dealer but you will most likely have to pay for it. Another highly possible cause for the problem could be dirty clutch fluid. The clutch fluid comes from the same reservoir as the brake fluid. Search the forum and you’ll find plenty of info on this and how to take care of it. |
