08-12-2011, 08:35 AM | #197 | |
knows 2 facts about ducks
A member just posted a DIY on the LED swap too. Doesn't look *too* hard, but I'm not a soldering expert so could be challenging for someone like me. |
08-12-2011, 10:16 AM | #198 | |||
Drives: IOM Bahia Int. 2LT RS M6 SR BH Join Date: Sep 2009
We better take this disscusion over to that thread http://www.camaro5.com/forums/showthread.php?t=162226
08-15-2011, 12:17 PM | #199 |
Drives: '91 RS Vert, '11 Grand Cherokee Join Date: May 2009
mrbrands5, where did you get your tubing to hold the LED and Light Pipe? What size is it and does the LED fit snug in the tubing or is it very loose. The reason I ask is the tubing I am using now is very loose and does not hold the LED snug. So anytime I make adjustments the tubing falls off the LED and its a pain to get everything lined up again.
08-16-2011, 12:16 AM | #200 |
Paul
I used 1/8" clear fish tank airline tubing. The LED and light pipe fit very snug.
08-16-2011, 11:44 PM | #201 | |
A very good tip from Gene Culley: I’ll give you some words of caution. When you turn the light tube to point the reflective strip in another direction, etc., hold the vinyl tubing with your finger and clinch tight. If you don’t, when you twist the light tube, since the vinyl tubing is connected to the LED, it will eventually break off the LED. I broke two LED’s doing this. Again, make sure you hold the vinyl tubing from twisting while you’re twisting the light pipe. I can tell you there is NO WAY to turn the light pipe in my clear tubbing. I had to remove the pipe every time I wanted to turn it a bit. It's that tight!
08-22-2011, 03:55 PM | #202 |
Tampa Bay Camaros
Now that I have the wiring harness & light tubes from Ofer, and the LED's from GM, I have a question... is the ABL wiring harness connector located behind the speedometer in a 2011?
I want to be sure that my ABL mod dims with the ABL in the doors.
08-22-2011, 05:13 PM | #203 |
Drives: 11 Camaro Vert 2SS/RS 6M Hurst Join Date: Feb 2011
the connector is behind the 4 gauge center console. It dims but only goes as low as the radio controls. it won't completely dim like the door panels or instrument cluster rings.
08-22-2011, 06:35 PM | #204 |
Tampa Bay Camaros
Hmm... so how do I fix this? I was under the impression that it would dim the same way the door lighting would.
08-22-2011, 07:53 PM | #205 |
It does dim. Just not completely. Go out to your car and dim the doors all the way. Your radio halos will still be visible but very dim. This is how the dash will be.
08-23-2011, 07:25 AM | #206 |
Tampa Bay Camaros
Hmm.. Is it distracting at all while driving at night? I like being able to turn off the doors, but I'm so used to them now that I don't even notice the glow while driving.
08-23-2011, 07:36 AM | #207 |
I was worried about the same thing when I was thinking of doing this mod. Honestly though, it just blends in with the rest of the ABL. Not distracting at all.
08-23-2011, 09:01 AM | #208 |
Tampa Bay Camaros
Thanks; that's reassuring.... With that, I'll begin the installation process on Friday.. hopefully it won't take too long.
08-23-2011, 08:12 PM | #209 |
Treasure Coast Camaro 5
Drives: 19 2SS vert, Mosaic Blk, A10 Join Date: Feb 2009
part list quick reference?
Hey guys, I've been watching his thread for a loooong time, I'm ready to pull the trigger, just need to know what parts and where to get them from- I know its covered in several of the 1,000 posts in here, but its taking forever searching from my phone...
I have a 2011 2SS, I want to complete the dash (non drill) and "fix/complete" the doors If someone can list the resources for me, id greatly appreciate it
08-23-2011, 08:51 PM | #210 | |
Similar Threads | ||||
Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
4th Annual GM Performance Parts LSX Shootout!! | nmcajeff | Dragstrip and Launch Techniques Discussion | 3 | 07-30-2010 12:05 PM |
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area | Info@PeddersUSA.com | USA - California | 6 | 04-30-2010 08:02 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
