03-16-2016, 11:04 AM | #15 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Simple Green.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
03-16-2016, 11:17 AM | #16 |
Meguires D101 cant be beat for a pro product that can be diluted various ways to use on exterior, interior, or whatever... Most ready to use APC's are ok ADAMS is exceptional but not cheap. I also love Optimum Power Clean which is another great dilutable product that can be adjusted for specific surfaces ect.
Laus Deo
03-17-2016, 03:20 PM | #17 |
If you have factory clear coated wheels. I wouldn't use APC on them for cleaning.
Repeated use of APC will strip waxes and sealants, leaving the surface unprotected. Use an iron removing cleaner, followed by claying, IPA 10% or Eraser, apply the most durable paint protection product you have, a sealant is good, a coating is better. Future cleanings of wheels will require only soap and water. If you have a spray wax, use it as a drying aid, it will speed drying, and decrease brake dust adhesion.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
03-18-2016, 07:03 AM | #18 |
Drives: ? Join Date: Oct 2011
Optimum power clean
