10-04-2021, 11:51 AM | #15 | |
Drives: 2014 Camaro SS 1LE Join Date: Oct 2019
Not a solid piece. It’s just what you see. There is no bottom. It’s a stamped piece - if that makes sense. |
10-04-2021, 01:18 PM | #16 |
Drives: Camaro 1LE Join Date: May 2018
Here's a few pictures of what's in the box. Actually surprised a little they included a blanket for the splitter. Headed out to get it blasted soon.
10-25-2021, 10:54 PM | #17 |
Well the white paint is no more. It should be getting sprayed within the week or so. Sorry no pictures of splitter with the white removed but I will when I get it back all painted. Just hope it matches the factory color and texture really well.
01-11-2022, 07:45 AM | #18 |
2014-2015 Camaro SS 1LE front bumper lip replacement
Has anyone tried the ikon front bumper lip since GM discontinued the original 1LE part? I am in need of a replacement too since a car ran over some road debris and cast it into my bumper lip.
ikon 1LE Splitter Front Bumper Lip PU BLF-CC141LE-PU |
01-11-2022, 10:34 AM | #19 | |
Drives: 1970 RS Z28, 1973 Z28, 2014 1LE Join Date: Aug 2011
Thank you Doug |
01-12-2022, 08:15 PM | #20 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I'd Like to see the Ikon Mounted on someones cars.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
01-14-2022, 04:08 PM | #21 |
Forgot to update my thread. Splitter turned out great. We used a black primer then sprayed WA8555 then a semi-gloss clear toned down a few extra clicks towards the matte side a touch. Yes flex additive was used as well. Finish is slightly darker in color and slightly more shiny compared to the stock unpainted plastic splitter. I would say it's really close to the 1le spoiler factory finish if anything. Overall very I am happy with the end results. Now at least I have a spare which hopefully I will never need.
01-14-2022, 09:15 PM | #22 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
That turned out GREAT! Like you said, hopefully you won't need it.
01-14-2022, 09:36 PM | #23 |
What brand is that.
01-14-2022, 09:53 PM | #24 | |
This is the GM factory style 1le splitter that my parts guy at my local dealer found me last year. |
01-15-2022, 08:24 AM | #25 |
GM stopped producing these too soon, Would be nice to be able to get the factory ones still, to me they are the nicest. I am not a fan of the one I got and it was not cheap.
01-15-2022, 12:56 PM | #26 |
Yeah I haven't seen a 1le style aftermarket one worth buying as of yet imo. I already had a handful of people wanting mine which says a lot.
01-18-2022, 06:40 AM | #27 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
How did you install?
I busted mine off and haven’t found the install kit to put it back. I can’t believe they discontinued all of the hardware and the splitter itself.
01-18-2022, 01:17 PM | #28 |
Not sure if your question is for me or not? I have all the included gm brackets and rivets for the factory splitter. I was planning on removing the one on my car and having it repaired after curbing it last year. But have since decided to just roll if it for the time being. I wanted a spare splitter and install kit for a worse case scenario situation. And if I never use it, then figured I could either sell it or it will stay with the car when I sell it.
