03-11-2024, 03:26 PM | #15 |
AC is one of those things that can get expensive because they usually recommended you replace nearly every part after a hard failure. All those lines, valves, seals, tight orifices, condensers, etc... they can hold on to (or be damaged by) debris from the compressor or part failure. Matter of fact, most companies will not warranty a replacement compressor without proof of condenser replacement, at minimum.
03-11-2024, 04:13 PM | #16 | |
David Vianu
2010 Synergy Green 1LT |
05-13-2024, 04:13 PM | #17 |
Drives: 2010 2LT/RS Black/IOM Join Date: Feb 2011
Well, this was awhile back, but they said that I got lucky and only needed a compressor. So now its about a month and a half later and its cool, but not cold. So I called the shop and I'm going to have them look at it again. My question is, should they be allowed to charge me again to diagnose this? If they didn't fix it right to begin with? Or is it just one of those, "it comes with the territory" type things?
Its going to the guy's other shop so the original crew wont be working on it, if that makes any difference.
ZL1 Factory Reproduction Wheels, Airaid CAI, MRT V 2.0 Axle Back Installed by PIE Customs, Painted IOM Rally Stripes, Bowties by Danny Taylor Louisville KY, IOM Engine Cover and Fusebox Cover by River City Creations and Lighting San Antonio TX.
05-13-2024, 04:57 PM | #18 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Depends on what has failed. If the compressor failed before but you now have leaking evaporator core, then it's on you. If something they messed with is now leaking (fitting not tightened for example), then it's on them. The grey area is something like a line they may have removed and reinstalled is now leaking, you would probably need to prove they damaged the line.
05-13-2024, 11:16 PM | #19 | |
I fully expected more than the compressor to be replaced, but I mean, whatdya do? Ill find out soon enough
05-14-2024, 08:09 AM | #20 |
If the clutch coil is what failed, no need to replace anything else. I wouldn't expect that to put debris in the system.
The fact that the system was low to start with might be a concern and maybe they should have tracked down the leak, which has probably continued to leak. Again, getting into a little bit of a grey area since it's hard to know exactly what was done from the description given. |
05-14-2024, 10:17 AM | #21 |
Drives: 2010 Camaro 2SS Manual Trans Join Date: Jun 2014
In 2021 I had to have my compressor replaced. Fortunately it was just before my extended warranty expired. The cost was $1,100 to the insurance group. If you have the V8, that compressor is buried near the bottom of the engine and I think has to be removed from below. The belt is what is called a "stretch" belt which means you need the special tool (readily available) to get a new belt on which should be replaced at the same time as the compressor. On my car, there was no noise out of the compressor, it ran fine and only had a leak. So, they only replaced the compressor and recharged the system. It now has 25,000 more miles and is still running fine. You do run some risk if you don't replace other components especially if the compressor is making noise. If they think there is metal in the system from the compressor, make sure they also flush the system. I am certified to work on A/C systems (can even do R12) and would have done it myself except that I had the extended warranty that covered it.
05-15-2024, 10:08 AM | #22 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I pull the passenger fender liner to get to the bolts and take it out the top, but I don't read the manual either. I also have turbo crap in the way so...
From what I understand the ball valves GM used on the high and low ports are the biggest leak problem on these. I have had them fail on my Camaro and Silverado. Easy replacement, but then you need a machine to recharge.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-16-2024, 12:43 AM | #23 | |
I wonder if I should tell the shop owner maybe look at those or should I just keep my mouth shut and let him inspect on his own. I don't necessarily want to tell the mechanic how to do his job just because I watched a few videos and got on a few message boards you know what I mean?
05-17-2024, 11:11 AM | #24 | |
