11-14-2012, 11:07 AM | #15 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
cooking spray, like Pam. Best thing to do is stick the sticker to a piece of Saran wrap, then lightly coat it with Pam. It will then stick to the windshield and you can remove and re-apply. Used to do this when I had to by a sticker to enter county park, then I could transfer between cars.
11-14-2012, 12:31 PM | #16 |
Drives: 2010 SS/RS Join Date: Jun 2012
you could try an arts and crafts store or office supply store. Look for window clings (it should be a clear vinyl that has 1 side that sticks to windows either with static or non-adhesive) just stick your parking sticker to the non-stick side and apply the sticky side to your windshield. Heres a link
11-14-2012, 12:36 PM | #17 | |
Drives: 2012 45 Anniversary Vert Join Date: Apr 2012
11-14-2012, 12:59 PM | #18 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Well, for now it's on my dash on a 3x5 index card. I don't know if they're on "patrol" today, but so far, so good. It's clearly visible, so I wouldn't think it'd be a problem.
That clear vinyl sounds like a good idea, too.
11-14-2012, 01:59 PM | #19 |
The Logistician
Drives: 2012 LFX 45th Anniversary Join Date: Aug 2012
I have a parking pass (rather large at that) and a gate sticker for where I live, and I also have the HUD. No problems.
11-14-2012, 02:46 PM | #20 |
Drives: 2010 CTS SportWagon 3.6 DI Join Date: Jun 2012
I use a piece of clear 1/8" thick Lexan (or plexiglass) with my sticker adhered to it. Put it in place when I need it and take it out when I leave. I slip the plastic piece between the dash and the windshield as needed.
11-14-2012, 03:51 PM | #21 | |
Drives: Black 2011 Camaro LS Join Date: Feb 2011
I already have 2 giant stickers there that I have to peel off once a year, its no big deal.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob SS Fascia, Factory RS HIDs, Plasma P13W fog lights Non-RS to RS and fog light harness by Gen5DIY LED Interior, Trunk, and Licence Plate lights in white ZL1 Spoiler with Gen5DIY harness Factory NPP cat back Blacked out tail light bezels Factory 20 inch wheels wrapped in Nitto Motivos Lowered 1.25inch on Eibach Pro springs |
11-14-2012, 03:56 PM | #22 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
or, just buy a second car just to drive to work, then you can put stickers on that one...
11-14-2012, 03:57 PM | #23 |
Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
I have a disabled person placard, which in the camaro is a pain to hang from the mirror.
I got one of these: http://www.amazon.com/Handicap-Placa.../dp/B004IM6BR2 look at the picture, it is a piece of plexiglass that tucks behind the A pillar cover. you can use that, maybe put the sticker on a 3x5 card or some such and then press it between the plexiglass and the windshield. FWIW, I didn't buy that one, I went to home depot and got a piece of plexiglass for $2 and cut/shaped it myself.
I'm only responsible for what I say, not for what you fail to understand.
11-14-2012, 04:09 PM | #24 | |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
01-29-2013, 07:08 AM | #25 |
Drives: mazda Join Date: Jan 2013
Dear i will suggest you to use the static cling for the parking stickers. It is reusable. You can stick it when you want. But use it from the inner glass. I have get these from custom stickers . The sticker is small sized. They will offer you vinyl too but select the static clings.
01-29-2013, 11:18 AM | #26 | |
Forever Pontiac
Drives: 2012 Black 2SS/RS Join Date: Oct 2010
01-29-2013, 02:38 PM | #27 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Can't believe the extent some people go, to do something simple. Just laminate the damn thing and throw it in on the dash. If you're worried about it, go talk to the security dept and ask them if that's acceptable. Personally, i'd just do the lamination and wait to see if there's a problem. That's exactly what I do and haven't had a issue so far, except when I forget to put it on the dash.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-29-2013, 03:34 PM | #28 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
They 'might' insist that you adhere it to the windshield so you won't be able to use the same sticker with more than one car like you could if you laminated it and layed it on the dash.
Who knows. Like you said, check with security. |
