02-21-2024, 06:22 PM | #15 |
Drives: Z/28 Join Date: Jan 2015
If your LS7 is stock, run high flow cats. If you have a head and cam package and track the car, you'll probably blow out the cats after a few events.
I ran high flow cats with my 1 7/8 ARH headers and ultimately blew out one of the cats after 2 track events (which also clogged up my mufflers). |
02-21-2024, 09:34 PM | #16 |
Drives: Chevrolet Camaro Z28 (2015) Join Date: Feb 2023
hey Joelster, I believe you... but which cat remover would you recommend? kooks come with high flow cats and I think they are welded into the headers
2015 Red Z/28. Seattle area |
02-21-2024, 09:35 PM | #17 | |
02-22-2024, 07:26 AM | #18 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Ideally, 2 inch LTH are best for the port shape of the LS7.
any 5th gen 1 7/8 LTH should also work however. I had a swapped LS7 and reused my 1 7/8s from the LS3. Worked just fine. |
02-22-2024, 11:21 AM | #19 |
02-22-2024, 09:33 PM | #20 |
I checked and you are right. any recommendation on where I can find a bypass tube without having to spend a kidney for it?
02-23-2024, 07:28 AM | #21 |
Drives: 2014 Z28 Join Date: Jun 2022
02-23-2024, 05:19 PM | #22 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
They shouldn't be welded. When I ordered mine, I ordered the non-catted h-pipe or whatever it was.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
02-23-2024, 06:31 PM | #23 | |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Now if you were to delete the stock LS7 oil cooler, any 5th gen header would fit just fine. I don't know if this is with every brand header out there, but I know I wouldn't risk trying it unless I was deleting the oil cooler. |
02-26-2024, 01:14 PM | #24 |
Drives: Chevrolet Camaro Z28 Join Date: Nov 2021
I guess billy boat exhaust isn't specifically for z28? 1-7/8 vs proper 2"
https://youtu.be/2iJBvHABbVI?si=JPrAPc7GOGkb0jRK
2015 Z28 SIM AC/Speakers #1228
2011 RAM 2500 6.7 diesel 2018 Husqvarna TE300 1985 Yamaha RZ500 |
