10-06-2023, 04:42 PM | #15 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I mean, I'm sure that's a crazy setup, but doesn't really meet the intent of a stick, does it?
10-06-2023, 06:10 PM | #16 |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
10-06-2023, 07:19 PM | #17 |
Drives: 2015 2ss Join Date: Jun 2015
10-06-2023, 07:47 PM | #18 |
Most "stick shift" classes specify a clutch assisted H-pattern transmission. I can see how your car doesn't fit a standard definition of a stick car from some perspectives. I would agree, a "stick" car, to me, has an H pattern trans.
I don't think there is any sort of sanctioning body for records like the one you're chasing, so if you want to claim it is a stick car, all the power to you. I would be prepared for arguments like you're getting here. My challenge would be to show me a "stick shift" class where your car fits the rules with regards to transmission. All the ones I know of specify H-pattern. I'm not aware of one that doesn't - but I'd be interested to be shown otherwise.
10-06-2023, 07:52 PM | #19 | |
That’s the group I race with been around since 2005. |
10-06-2023, 07:54 PM | #20 | |
10-06-2023, 07:56 PM | #21 |
Raced the car with the factory TREMEC until I broke it 2 times back to back
Put a Jerico in it and H pattern and broke it 2 times. Went to the liberty this year. |
10-06-2023, 08:35 PM | #22 |
2&THEHIT
stickS shift record holder
Post some pics! Let us see!! |
10-06-2023, 09:17 PM | #23 |
10-07-2023, 01:26 PM | #24 |
2&THEHIT
Nicccce
Totally awesome that you're running the SBE in a racecar. |
10-07-2023, 02:39 PM | #25 | |
10-08-2023, 04:36 AM | #26 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Awesome build! Being in the machining, fabricating, & manufacturing field for 30 years I truly appreciate the level of craftmanship you have!
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
10-08-2023, 05:44 AM | #27 |
Damn thats nice!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-30-2023, 07:27 PM | #28 |
