Old 05-30-2014, 12:06 PM   #15
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Originally Posted by jeremywes View Post
Probably not but you can use an OEM rear bolt on the front. Not quite as good but better than no adjustment at all.
Not quite as good, In what way?
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 05-30-2014, 03:09 PM   #16
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
The Pedders bolts were race grade, tig welded and cadmium coated. The eccentric was also a little bigger which allows for more adjustment. I do have a set of factory rear take offs if you want them you can have them just IM me your address and ill send them to you.
jeremywes is offline   Reply With Quote
Old 05-30-2014, 06:28 PM   #17
White_SS/RS
Drives: 14 1LE
That was pretty much what I was thinking.
Anyone know how much the rear take offs will allow in additional caster?
LMS Engineering
Old 05-09-2024, 10:33 AM   #18
Unaf-Ford-able
Drives: 2010 Synergy Camaro
....and are apparently no longer available. Seems to be a thing with the 5th gen here of late.
Unaf-Ford-able is offline   Reply With Quote
Formal High-perfomance Education? Dan3 General Automotive + Other Cars Discussion 11 06-08-2020 01:52 PM
Camaro vs Corvette? Dr Jkel Chevy Camaro vs... 71 11-12-2010 01:39 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Please Post Details from the Chats! jmliptak 5th Gen Camaro SS LS LT General Discussions 0 07-22-2008 09:06 AM
