#Camaro6
Old 04-11-2024, 08:32 PM   #421
Camfab
Drives: ‘23 ZL1-1LE
Originally Posted by Bumbleboy92 View Post
Thank you!
I also double checked #112 and am certain it’s sequence is 107229 as the warranty says Mexico while the other sequence (107251) says Colombia
Not sure what you do for a living, but it seems investigation may be up your alley. Nice Job!
Camfab is offline   Reply With Quote
Old 04-13-2024, 04:50 PM   #422
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
THIS IS AWESOME!!! Thank you...
We will be able to have a complete list in the end...
I wonder how many numbers will be sequential with the VIN and if any will get cherry picked to be #2 etc.
7 months later and it's done!
SwL_Wildcat is offline   Reply With Quote
Old 04-13-2024, 04:51 PM   #423
SwL_Wildcat
Drives: 2024 ZL1
Well, I think the road may be at its end.
The Excel file should have all 350 ZL1 VINs now if I'm correct (which I'm betting I am)
Excel file (linked on first post)
Attachment 1149657
I'll explain my process since no new cars were being posted on social media for the missing Mexico cars. I thought to cut down on a lot of guesswork the best way would be to find the sequence of the other cars that were built off of Lansing Grand River Plant. The only other two are the Cadillac CT4 and CT5, with a few changes to the script I'm pulling the data on them (it's been almost a week and I'm almost done, why does Cadillac have so many different variations). When it's finished I'll give a visit to their respective forums to see if anyone's interested in that.
I added the 2024 Camaro data to the 2024 CT4/CT5 data I pulled and the sequences line up perfectly in many cases. I used the gaps between known CE ZL1 cars as starting points and tried to find anything.
Unfortunately, since the Mexico cars aren't kept in the US VIN systems, I couldn't find any way to verify if a VIN was right. Until I found the warranty check site from GM.
https://experience.gm.com/ownercenter/recalls?vin=
While not an API endpoint like the window stickers, I was able to test the potential cars against that. Again the information the site gives isn't much but I did see a pattern.
CE #001: https://experience.gm.com/ownercente...FJ1R6XR0100021
Results in a 2024 Chevrolet Camaro A with active warranties.
For example a test VIN: https://experience.gm.com/ownercente...F91R65R0103028
Results in "Currently, there are no recalls or warranties for your vehicle..." etc.
So not a match there. But the match can be found here:
https://experience.gm.com/ownercente...F91R68R0100043
"2024 Chevrolet Camaro A" and if you scroll down the warranties say Mexico.
Thankfully it seems the missing ZL1 cars were the only ZL1s sent as I didn't find anything that didn't match the missing CE ### ranges. (Minus #112 which is potentially one of two VINs. Both Mexico ZL1's and both match in the range of 112)
My minor obsession with 'find them all' is over.
For now...
Excellent work! Thank you for the dedication! I had all but given up on finding all the Mexican cars.
Old 04-13-2024, 08:00 PM   #424
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I did for a bit as well but once I found out the CT4/CT5 was the only other car coming out of the same factory I thought it was worth another shot.
Here's the file of every single sequence found from 100001 - 130000 out of the plant (Camaro, CT4, CT5)
https://1drv.ms/x/s!AsH22DOMp_qsq94b...-QNAQ?e=FE1nV8
The 2024 Cadillac only file I used in search of missing sequences since the Caddy has so many different identifying VINs
https://1drv.ms/x/s!AsH22DOMp_qsq9Vm...77OAw?e=3Kg3KI
From what I've searched the 2024 CT4/CT5 is still going till end of May, I only did up to 130k sequence since the Camaro only went up to that for 2024. I'll get the rest in June probably
Although, now that I’ve put it together in one file, I can assign the missing sequences their corresponding VIN’s. I’ll take a look and see how much work that would be, maybe even get a count of cars sent out of North America
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 04-14-2024, 10:25 AM   #425
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Old 04-19-2024, 01:11 PM   #426
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
#181 FS on BAT for the second time.
https://bringatrailer.com/listing/20...ro-coupe-16-2/
It was previously sold on BAT
https://bringatrailer.com/listing/20...maro-coupe-16/
