Old 08-11-2012, 12:40 AM   #4873
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
pretty good run!
I believe you now, but Chris is probably a little more hard-asst than me... he'll be needing timeslips and vid... and a note from your mother
I only have 2 slips. One is 12.06 and this one. Can't find any others.
Name:  New Picture (3).jpg
Old 08-11-2012, 01:59 AM   #4874
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
nice photoshopping skills.
Old 08-11-2012, 02:33 AM   #4875
PQ
Booooosted.
PQ's Avatar
You got me. I was cutting him some slack. Here ya go............
Old 08-11-2012, 07:03 AM   #4876
600hp-lpe
Drives: 2010
nice 2nd run Randy.. You win most improved... for back to back runs.
How'd you get to the start line so quick for run #2? LOL
600hp-lpe is offline   Reply With Quote
Old 08-11-2012, 09:12 AM   #4877
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
I piss excellence
and fart awesomeness
Old 08-11-2012, 09:45 AM   #4878
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
Eve ('00 FRC): hot-air intake
Old 08-12-2012, 12:54 AM   #4879
TAG UR IT
TAG UR IT's Avatar
Attachment 409944
Old 08-12-2012, 02:23 PM   #4880
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
LOL
It's not good enough that I was DQ'd as a no show, but he has to rub it in with a photoshop'd time slip...
Old 08-12-2012, 02:34 PM   #4881
zebra
zebra's Avatar
a "win" is a win, right?
Old 08-12-2012, 03:03 PM   #4882
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
LOL
It's not good enough that I was DQ'd as a no show, but he has to rub it in with a poorly photoshop'd time slip...
fixed it for you
Old 08-12-2012, 03:06 PM   #4883
GTAHVIT
Blessed
GTAHVIT's Avatar
Front Brake Upgrade
CTSV Front Calipers with ZL1 Rotors, Hawk HPS pads (low dust), SRF fluid (liquid gold) and Pedders stainless steel brake lines.
The hardest part is getting all that old fluid out of the system in order to put in the SRF... yes It's expensive... and while we were bleeding the lines I could almost hear the cash register as wasted fluid was lost...
LOL
We basically disconnected every line at the ABS and at each caliper. Blocked off each one and bled every line to the ABS individually, then cycled the ABS to ensure that as much of the bad fluid as possible was out of the ABS. Then we flushed out the lines to the calipers and after a couple hours had it all flushed and bled with the new fluid.
It took Way longer to flush and bleed than it did to install the calipers/rotors/lines.
I'm super happy with them. The pedal feel is much more firm. I'd even say there is more feed back to the pedal under hard braking. The control under braking is significantly better... the steering wheel doesn't even try to move left or right. The bias is much better front to rear from a seat of the pants perspective.
Since my car is a daily driver I went with a street low dust pad, but that may have been a mistake. Well, from a performance perspective I know it was a mistake. Basically with a DD pad, I'm only getting partial benefit from the improved clamping power of the front calipers. in order to completely capitalize on the 6 piston fronts I need a more aggressive pad.
If I end up tracking the car as much as I hope to I will probably swap pads for a more race compound with a higher coefficient of friction to take full advantage of the upgrade.
As it is now, from what I've been told by Pete and Bruce Raymond and what we've heard about the ZL1 brakes from the articles, the biggest benefit is the lack of brake fade. The setup I have will be much more consistent than the stock SS brakes.
I'd say I'm stopping about 10% shorter than before at most. Pete and Bruce say that with racing compound pads that will drastically increase.
On a side note... I've always wanted red powder coated calipers. Back when my Step Dad was just getting me started working on cars, we always thought the guys who took the time to powder coat the brakes were taking that extra step to do it right.
All in all this is one of my favorite upgrades.
Gotta say thanks to Jim Hartley for the use of his lift and his and his son's expertise.
Old 08-12-2012, 04:28 PM   #4884
garcmol
garcmol's Avatar
Those look great! Just that new fluid will reduce a ton of fade. Doubt you will see much now.
Old 08-12-2012, 04:43 PM   #4885
PQ
Booooosted.
PQ's Avatar
You need to take some soap and water to those rotors. They are dirty. should be silver color.
Old 08-12-2012, 07:08 PM   #4886
zebra
zebra's Avatar
that said, while you're at it, you should also get a chisel & carve some slots in them, too
gta has no internets, gta needs glasses, is there a car here?, mrs. gtahvit > gtahvit, they stay on the mantle, weak car needs more power
All order status requests in here (up to status 3800). List of Order Status Codes. GTAHVIT Camaro Price | Ordering | Tracking | Dealers Discussions 54436 12-28-2016 08:04 AM
Build from Scratch The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 18 04-23-2010 09:39 PM
Missing "Ladies of Camaro 5" thread comment.... Silverado Off-topic Discussions 2 10-08-2009 12:23 PM
Why An april build is just as good as a March build Sean_W Camaro Price | Ordering | Tracking | Dealers Discussions 10 02-07-2009 02:51 PM
