Old 11-29-2010, 03:44 PM   #57
DRG BSTN SQUIRREL
DRG BSTN SQUIRREL's Avatar
Drives: 2011 Camaro 2SS
Originally Posted by xx_ED_xx View Post
Then other then some basic safety stuff, your wallet is the limit.
That can be an issue.... not really a bad one, just how far she will let me go!
DRG BSTN SQUIRREL is offline   Reply With Quote
Old 11-29-2010, 03:48 PM   #58
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
LOL, yup me personally I would get the motor apart replace what is needed make sure everything else is up to par and start there.
xx_ED_xx is offline   Reply With Quote
Old 11-29-2010, 03:50 PM   #59
DRG BSTN SQUIRREL
Im gonna drop a dummy block (454) in just to get the front suspension "tuned" in, then get all the braking system done, then fuel cell, seats, wiring, all that fun stuff then the motor will get started.
Old 11-29-2010, 03:51 PM   #60
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
instead of fully tubbing your car and just did a mini-tub, that would pretty much have you set for running as many classes as possible (running a big block disqualifies you from a good bit though).
Other than that.... go at it..... Just remember.... safety first.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 11-29-2010, 03:51 PM   #61
xx_ED_xx
xx_ED_xx's Avatar
There is a set of headers that fit pretty well especially with the better k member you have i just dont remember what they were. I want to say 2nd gen hookers
Old 11-29-2010, 03:54 PM   #62
DRG BSTN SQUIRREL
I was looking in the Kooks headers buuuut the price! AHHHH! I think I read before that the 2nd gen hookers are a good match. Saftey... yes ALWAYS! Id rather spend tons on that before I get something to "just get by".
Old 11-29-2010, 04:06 PM   #63
danhr
BAMF SS
danhr's Avatar
just to go down a quick list of things i think you will need:
transmission shield
driveshaft loop
arp wheels studs
6 (or 8) point roll bar AT MINIMUM (dont know specs on motor, so I dont know if you are going lower than 10.0)
Helmet
Stock Longblock
Old 11-29-2010, 04:52 PM   #64
DRG BSTN SQUIRREL
Got the cage, thats it for now HAHAHAHAH!
Old 11-29-2010, 04:55 PM   #65
DRG BSTN SQUIRREL
Old 11-29-2010, 04:58 PM   #66
danhr
BAMF SS
danhr's Avatar
cm or mild steel?
Stock Longblock
Old 11-29-2010, 05:03 PM   #67
DRG BSTN SQUIRREL
Mild steel
Old 11-30-2010, 04:48 PM   #68
redracer1
I Feel The Need For Speed
redracer1's Avatar
Drives: 2002 35th Anniversary SS/LE
awsome build....and have you looked into an EFI system for the 427 not cheap but would be much more tunable.
http://www.fuelairspark.com/Products...ts'-0.aspx
Chris'
2002 35th Anniversary Camaro SS/LE #30
2001 Brickyard 400 Track Car#10 SLP#101
http://www.socalmuscle.net/ http://www.losangelesinvasion.com/
redracer1 is offline   Reply With Quote
Old 11-30-2010, 07:22 PM   #69
xx_ED_xx
xx_ED_xx's Avatar
Yes I was hoping he went efi as well, but I have a feeling a carb is going to end up on it.
Old 11-30-2010, 09:30 PM   #70
DRG BSTN SQUIRREL
Price =
BMR Launches New Product - 67-81 F-Body Delrin Body Mount Bushings BMR guy 1st & 2nd Gen Marketplace 0 05-17-2010 03:38 PM
extreme deminsions wide body kit INSAINE RIDE Vendor and Seller review / feedback / experiences 27 05-06-2010 06:09 PM
Wide Body? Cmlloveless Cosmetics and Lighting Modification Discussions 12 05-04-2010 02:03 PM
Best method to clean a throttle body on '99 Z Broshot 4th Generation Camaros 5 07-19-2009 11:50 PM
body color matched body kit (ground effects)? jordan 572 Cosmetics and Lighting Modification Discussions 9 04-30-2009 05:39 PM
