03-06-2011, 11:00 PM | #1 |
Mods to reach 600hp?
I was wondering if anyone had any ideas on what modifications I should put on my 2010 Camaro SS/RS L99 A6 to get the hp to around 600hp but not completely emptying the savings account.
03-06-2011, 11:31 PM | #2 | |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
How much $$$ do you have to achieve this goal. Unless your going spray your gonna need probably 12k to reach those numbers in RWHP. You will need a SC first of all. Some long tubes, fuel rails to push those kinds numbers plus most likely some forged internals. Your tranny might also not hold up to a 600RWHP. Your looking at major dinero even if you do the work yourself. |
03-07-2011, 06:40 AM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
what he said! we have 3 guys in our club that are pushijng those kinds of numbers.....the cars are BEASTS! but to do it right.....those are the numbers you are going to spend. one thing he didn't mention was the rear end.....you will or should replace the rear axcels as well.
03-07-2011, 04:12 PM | #4 |
So what do you reccommend then
Thanks for the advice so instead of trying to get it to 600hp what mods should I get then.
03-07-2011, 04:18 PM | #5 |
Drives: 2013 Chevy Truck Join Date: Mar 2010
I would start with LT Headers, CAI and exhaust if it is in your budget. Then save alittle more and move on to CAM, Suspension, CLutch, Gears, Hardened Half Shafts, etc.
I have been working on mine piece by piece.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me! |
03-07-2011, 04:19 PM | #6 |
I have 625rwhp and I have Maggie TVS2300, Cam, Headers, ADM Street Intake, High flow cats, muffler delete...
03-07-2011, 04:38 PM | #7 |
Drives: 2010 Camaro Join Date: Feb 2010
Do you want it to last??? If so its going to be well more than 12k. The L99's are much more costly when it comes to making power. Most of the blowers with a slightly smaller pulley (more boost) will reach 600 rwhp fairly easy. But the L99 is a differnt story. You'd have to make at leat 13/14 psi to get to 600 rwhp and the bottom may not last long. An example. My car , L99, with 10.5 psi on a maggie and all the bolton and on meth made 545 rwhp. Thats prob as far as you want to push the stock block. It took an LS3 conversion (cam and valvetrain change) and a smaller pulley just to get two 625. Trust me, it was all much more than 12k. How long did a stock bottom last at 12.5 psi.....not very!
03-07-2011, 04:51 PM | #8 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
It would give us more of an idea if we knew what you use your car for, what your goals are, and how much $$ you want to spend.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-07-2011, 06:48 PM | #9 |
Drives: 2010 Camaro SS Join Date: Oct 2008
I would say your going to spend 15k or better to get those numbers....
You could get around 500-530Rwhp for 12k..... |
03-07-2011, 07:17 PM | #10 |
i want to show it as well as race it even though it is automatic
03-07-2011, 08:46 PM | #11 | |
TRI COUNTY TAMPA
Then that is going to cost even more as you need something nice on the outside to show off as well. As for the HP $ Take it from the guys who have achieved those numbers. They can give you more accurate numbers. Obviously my numbers were only a bare minimum number to get close to that kinda GO-FAST. You would probably easily be looking at $25k to really get a start on a 600HP show vehicle. If you want to see a SC show car look at Veteran1. Now that's some serious cash right there. |
03-07-2011, 10:15 PM | #12 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
I'm running the kinds of numbers you're talking about. With having a reputable shop do all the installations I've calculated on average that it costs right around $100 per horsepower. Some is cheap hp, some is expensive hp, but on average thats a good rule of thumb.
Similar Threads | ||||
[COTW 11/28/11]: 2010 CAMARO 2LT RS LOTS OF MODS!!!!!!!!!!! | camaro2lt | Member Car Journals | 224 | 12-04-2011 11:33 AM |
Anyone adding MODS over the winter? | 600hp-lpe | USA - New England | 198 | 04-13-2011 08:03 AM |
Drifting in my 2010 Camaro + LC and 0-160 run after mods..!! | walhan_qtr | Camaro Photos | Spyshots | Video | Media Gallery | 1 | 05-06-2010 01:40 AM |
Mods: Before or After Break Inn? | jpetro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 11-08-2009 03:42 PM |
G.M. and Union Reach Deal on Contract Changes | Tran | General Automotive + Other Cars Discussion | 25 | 05-22-2009 11:01 AM |
