03-28-2023, 10:14 AM | #1 |
Drives: 20 ZL1 m6 Join Date: Apr 2022
15in conversion tire size
Hey I have a 2020 zl1 looking to do a 15 inch conversion and the car has a manual trans. What size Hoosier would work best? How wide can you go without clearance issues?
03-31-2023, 06:30 PM | #2 |
STOCK ELIMINATOR
Drives: STOCKER Join Date: Aug 2015
I run a 30x9 radial slick on a 15x10 inch rim no rubbing anywhere been 1.35 60'
5664 AA/SA
1970 NOVA |
03-31-2023, 09:51 PM | #3 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
What kind of power are you making that you need a 15" conversion? I ran a 17" with 850 rwhp on my 16 SS and hooking with a 305-45-17 MT Street R, ran 9.41@147 w/1.35 60ft. Just trying to save you some money that you could use some place else. I run a 17" Hoosier 28x10-17 with 707 at the wheels and you for sure need a slick with an M6. I'd look at the 28x10 or the 28x10.5-17 Hoosier as you mentioned in your post above.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
04-04-2023, 12:17 PM | #4 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
275/60/15
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
04-04-2023, 02:58 PM | #5 |
Drives: '20 ZLE Join Date: Jun 2020
I had to comment on your signature, 9.58 @ 145mph, when I ran 10.35 at 145 last weekend. Something's not right here.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
04-04-2023, 05:17 PM | #6 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Nothing weird about 9.58@145. I’ve run multiple 9.6x at anywhere from 145-149 MPH. Your time is what it is because you were having traction issues but your trap speed shows that’s you’re making good power.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
04-04-2023, 05:18 PM | #7 |
I’d do 325/50/15 unless you’re in a class that requires the smaller tire…
04-04-2023, 07:01 PM | #8 | |
BAMF SS
How much rwhp? picking a tire without knowing those two things is pointless.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
04-05-2023, 03:14 AM | #9 |
i have seen a few guys go 325/50/15 then switch to the 275/60 and saw no improvement
04-05-2023, 04:24 AM | #10 |
He runs at my track (wwtraceway), its a twin turbo that he's still dialing in, turbo 400 conversion. Should go in the 8s when he's done tuning it.
04-05-2023, 08:11 AM | #11 | |
STOCK ELIMINATOR
If you want to know how well your car is working do this, 1320 divided by your mph! That will tell you how well your combo works, my Stock eliminator cars will out run this calculator or right with it. When this car is all dialed in I'm hoping for mid 8's at 155 or so.
5664 AA/SA
1970 NOVA |
04-06-2023, 05:04 PM | #12 | |
'20 ZL1 1LE A10.
04-10-2023, 10:52 AM | #13 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
The answer to your question is that the 10.35 ET was under performing relative to the 145 trap speed. Not unreasonable to expect mid-9s ETs with a 145 trap speed on a decent run like TOSTO reported.
06-06-2023, 09:44 AM | #14 |
Tags |
15in, hoosier, racing, tire size |
