01-20-2024, 07:09 AM | #1 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
10 Rib CONVERSION ???
Hey Team, Just curious who here has done a 10 rib conversion? Wondering how long it look to install, and where you are getting the belts from... Any down sides aside from the $1k cost?
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
01-20-2024, 07:47 AM | #2 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Pretty easy upgrade, couple hours of work to do the THPSI setup. 10 rib isn’t needed at your power level but the LT5 tensioner is a nice upgrade for more travel and stronger tension. Will be good if you decide to crank up the boost down the road.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
01-20-2024, 08:03 AM | #3 |
Thank you sir... I am planning on purchasing the Katech Dual Drop in Pumps, when they release the plug and play harness in the next few weeks, along with a Big Gulp.
With the extra lowside capacity, ill be running straight E85, and figured id also bump the lower pulley to add another pound of boost... So when looking at lower pulleys, I saw the 10-rib kits, and thought that it might be time to upgrade... I am pretty sure, Ill be happy with 850rwhp +/- and wont need more than that...
01-20-2024, 08:37 AM | #4 |
Drives: '20 ZLE Join Date: Jun 2020
I installed this DSX upper idler bracket with 8-rib belt, which eliminated any slip
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
01-20-2024, 12:50 PM | #5 | |
01-20-2024, 02:20 PM | #6 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
where do you find the LT5 tensioner?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
01-20-2024, 03:23 PM | #7 |
You cannot just run the LT5 tensioner as the bolt pattern is different. TooHighPSI CNC cuts out the specific bracket you need out of billet aluminum. I have a pic or two in my build thread.
02-05-2024, 12:37 PM | #8 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
i might be interested in this since i bought the supercharger head spacers. 5 mm doesn't sound like a lot. But it makes a huge visual impact as well as all the wiring harnesses are significantly tighter, And obviously the belt will be a close fit also. So a tensioner that has a bit more throw would be nice. I'm sure it will help with temps though. Today, February 5th it was like 93...
02-06-2024, 05:45 AM | #9 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Sorry to get off topic but how was the spacer install. I want to do this but can't find much info about it anywhere for some reaaon.
02-06-2024, 07:29 AM | #10 |
You should start a new thread about that since this one is about the 10 rib conversion.
