02-19-2024, 04:44 AM | #1 |
Drives: 2021 LT1 Camaro Join Date: Jul 2022
Build ideas for older supercharger
I recently purchased an Edelbrock E-Force supercharger #1559. Was brand new in the packaging for very cheap so I decided to grab it. My car is a 2021 LT1 Camaro with the 10speed running LT2 manifold, e85 and LT5 throttle body. I'm looking for any build ideas, preferably best bang for buck supporting mods, and maybe some more info on this supercharger if anyone currently has it or has used it before.
02-19-2024, 06:52 AM | #2 |
Drives: 98 Camaro Join Date: Apr 2022
You are gonna need to do atleast a Jms booster on the low side of the fuel system and the lt4 high side and injectors would get you around e50. That’s a 50/50 mix. Throttle body will work, might need to change air intake pipe. Headers and other mods aren’t really needed until you up the power
02-19-2024, 08:24 AM | #3 |
Drives: 2018 Camaro SS Join Date: Sep 2009
It’s not going to give you any glory but relieving crankcase pressure would be at the top of the list for me. The LT1 has the poorest crankcase ventilation of any current v8 in production. I don’t think it is sufficient even in stock form with zero boost. Get a catch can that vents and put a hose on top of it to route the fumes out of the engine bay or you will smell horrible fumes every time you drive anywhere. If it is not addressed you will blow the front seal out of the front cover and you will then have a major oil leak. Beyond that I would say a pulley is going to give you the max bang for the buck until you hit the fuel limits of the lt1. At that point you will need to upgrade to LT4 pump and injectors
02-19-2024, 08:44 AM | #4 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
All good points mentioned so far.
One thing to clarify, The LT1 fuel system will be near or at it's limits soon as the supercharger is bolted on. There is no room for pullying down. It would be octane limited on 93 even if it had more fuel system available. It will need the LT4 high side and JMS low side minimum, and the ethanol will need to be blended to around E50 as mentioned in post #2. If the OP wants full E85 then he is going to have to look into a LPE HPFP pump and +30 injectors which would be capable on 8-9psi. Pulley down for 10-11psi and you will be blending to E60 unless targeting a lean AFR. Or go Port Injection.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
02-19-2024, 03:52 PM | #5 | |
02-19-2024, 04:02 PM | #6 | |
02-19-2024, 04:59 PM | #7 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
TooHighPSI is probably the best port injection kit in the market currently. If I had to do it all over I would have went port several years ago. 91 is trash fuel for a supercharged high compression engine so I’d do what I could to avoid that. It’s fine for cruising but way below optimal under boost so do what you can to run at least a blend of ethanol.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
02-20-2024, 04:57 AM | #8 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
I agree on the Too high port i just switched to it so i could run E. I made huge gains
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
02-20-2024, 07:17 AM | #9 | |
02-20-2024, 08:07 AM | #10 | |
I run +30 injectors / LPE HPFP / LT4 lows side with JMS and it supports E60 @ 11psi. I went this way because there were no affordable PI setups at the time(2019) and these DI fuel components were half the cost of what they are today. So If I was starting over in 2024, I would likely have port on my car and I would probably go with Katechs dual drop in pump.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 02-20-2024 at 08:26 AM. |
02-20-2024, 11:34 AM | #11 | |
Petro-sexual
If you have to worry about smog, this kit is not going to pass... If this doesn't matter, then kudos' and congrats' on your purchase.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
02-20-2024, 04:11 PM | #12 | |
02-20-2024, 04:14 PM | #13 | |
02-20-2024, 05:44 PM | #14 |
Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
I'll have to second the talk about going with the THPSI kit with the JMS BAP. I had done the LT4 fueling and meth prior to hearing about the port kit but since the install nothing but pure joy. You can't beat the power and safety the port allows you.
p1sc1 factory box w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
