Old 11-16-2012, 07:32 PM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Aftermarket dual tip axle-back to work with 1LE diffuser?
My current set up on my SS is a SLP Loud Mouth II. I love the looks of the dual tips on the ZL1 and the SS with the 1LE option. Just wondering if there is anyone making an axle-back (dual-tip) that would work with the 1LE diffuser. I would love to make that my next mod, but I know buying the whole exhaust through GM would cost an arm and a leg.
newagemuscle is offline   Reply With Quote
Old 11-17-2012, 06:32 AM   #2
newagemuscle
Philippians 4:13
Am i the only one that has considered this? I would have expected atleast one person to chime in.
Old 11-17-2012, 06:37 AM   #3
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I'm pretty sure the Holes in the 1LE and ZL1 diffusers are in the same spot.
I've done a few custom exhaust systems with both diffusers and don't remember having an issue with the holes not lining up.
Corsa and Stainless works makes dual tip exhausts and i'm sure there are others.
IDEALG is offline   Reply With Quote
Old 11-17-2012, 06:44 AM   #4
newagemuscle
Philippians 4:13
Really... i guess i have never compared them side by side. I assumed the dual tip diffuser openings were slightly lower. Ok... so is anyone in the aftermarket making a dual tip axle-back?
Old 11-17-2012, 08:49 AM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
You could weld quad tips onto any exhaust that you want, so you could choose based on sound, not just availability.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 11-17-2012, 09:11 AM   #6
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
I used this tips with what i had already.
http://tips.byethost4.com/index.html
Old 11-17-2012, 09:26 AM   #7
newagemuscle
Philippians 4:13
Nice... is the quality as good as they look in the pics?
Old 11-17-2012, 09:36 AM   #8
UF4LIFE102SS
Drives: 2010 2 SS
So far they r just great, they r solid.
Old 11-17-2012, 09:50 AM   #9
newagemuscle
Philippians 4:13
Any pics
Old 11-17-2012, 11:04 AM   #10
IDEALG
IDEALG's Avatar
I installed two sets of those tips above already for a guy and they worked perfectly. you can weld them on no problem. you will just have to modify whatever exhaust you choose so it exits in the center of oval hole instead of the original ss diffuser hole.
Old 11-17-2012, 03:54 PM   #11
newagemuscle
Philippians 4:13
Is that the 1LE diffuser? That looks great. What muffler or axle back are you attaching to? I have the SLP LMII axle back. That is what I would want to attach those tips to. Fortunatly the LMII axle back tips just clamp on, so if all goes well this should be a fairly easy mod.
Old 11-17-2012, 04:03 PM   #12
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
I think that is a custom diffuser
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 11-17-2012, 04:21 PM   #13
newagemuscle
Philippians 4:13
Think your right. I just looked up the 1LE. I forgot that it is open at the bottom where this one is not.
Old 11-18-2012, 10:27 AM   #14
UF4LIFE102SS
Drives: 2010 2 SS
I have complete LG exhaust. The diff his from OFER!
http://www.gen5diy.com/index.php?rou...&product_id=60
After core it is $350.
