06-08-2011, 03:16 PM | #113 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
06-10-2011, 08:47 AM | #114 |
Drives: 2010 2SS/RS Black w/ Silver Stripes Join Date: May 2011
Bringing mine to the dealer next week
I have an appointment at Flemington Chevrolet in NJ where I bought the car new about a month ago. My pop/clunk/rattle started at 400 miles, right after my PA inspection. I'm starting to think that when the car was on the lift with all the suspension hanging down the coil spring became unseated in the isolator. We'll see, but I can not live with this noise. I will invoke the lemon law eventually if they can not fix it.
06-10-2011, 10:16 AM | #115 |
Drives: LT RS Automatic Join Date: Dec 2010
Subscribed.
06-10-2011, 03:10 PM | #116 | |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
06-10-2011, 04:53 PM | #117 |
Gearhead
Drives: 2010 2SS/RS L99 Join Date: Oct 2010
I've got this problem, too. My passenger side header was tapping against the subframe. Got it fixed, and this noise continues. Didn't have a clue what it could be until I found your thread. Gonna buy the rubber gaskets this weekend, but frankly I'd rather see Chevy release a fix. You said it at the beginning. For a $40K + automobile with a long period of development, there shouldn't be annoying issues like this... Thanks for the fix.
Come on Chevy, give us a fix for this. |
06-10-2011, 05:05 PM | #118 | |
Drives: Camaro Justice Join Date: Jun 2007
Here is my check list for a 5th Gen with OE coils and a noise in the front suspension. 1. Check that the endlink nuts are tight to GM spec. 2. Check the nuts on the ball joints in the knuckle to verify they are to GM spec. 3. Check the clevis bolts to be tight to GM spec. 4. Check the radius arm bolts to be tight to GM spec. 5. Check the lower inner LCA bolt to be tight to GM spec. 6. Remove the retaining plate on each strut. Burp the exposed nut with a rattle gun. Reinstall the the strut retaining nut with the same rattle gun. 7. Inspect the upper coil insulator. If it is black rubber, replace it with the update steel and urethane version. 8. If the noise persists, get out the chassis ears and isolate the noise for repair. If it were my personal 5th Gen, My spec would be German. GUDENTIGHT with a couple of extra grunts. You may want to print this and take it to the Dealer. |
06-10-2011, 10:52 PM | #119 |
I wouldn't tighten the nut. My rattle was barely audible until I did that. Chassis ears got me in the area, but I still haven't pin pointed it yet. I'm thinking it is the end link. I'll know more maybe after this weekend.
06-10-2011, 11:08 PM | #120 |
Drives: His Wife Crazy Join Date: Jan 2008
where is denham springs?
06-11-2011, 01:05 AM | #121 | |
www.Camaro5store.com
06-11-2011, 08:49 AM | #122 |
06-11-2011, 09:15 AM | #123 | |
Drives: GM Vehicles Join Date: Jun 2010
Jeff Morris, Chevrolet Customer Service |
06-11-2011, 09:35 AM | #124 |
Listen to Pete, print out that post and bring it in to your local dealer.
you might want to consider a dealer that is more experienced with the performance market too, if you can't get it taken care of locally, Brian Harris is about 1.5 hours from you, just a thought that might help. Brian Harris Buick GMC Pontiac Mazda 293 Howze Beach Road Slidell, LA 70461 Ph: 800.773.0831 williams@brianharrisslidell.com |
06-13-2011, 12:23 PM | #125 |
Loose parts make noise. Tight parts do not. The strut assembly bolts have to be tight. If you tighten a bolt and the noise increases, that tells you there is another issue. What needs to be done is we drill down and find the source of the noise.
06-13-2011, 12:37 PM | #126 |
I agree. I have another vehicle to drive now so the Camaro is sitting until I get back from vacation. I'll take some time to figure it out then. My strut nut wasnt really loose per se, but I did get it to move a 1/4" with my impact. I gave since retorqued them with a torque wrench. I still think it's a bad end link.
Similar Threads | ||||
ZL1 / CTS-V Brakes | JusticePete | Suspension / Brakes / Chassis | 584 | 10-14-2021 09:33 AM |
Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 02:18 PM |
Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 11:57 AM |
2010 Camaro SS Blue in Syracuse NY $32690 | Mitsubishi in Syracuse | Camaro Price | Ordering | Tracking | Dealers Discussions | 0 | 12-31-2009 02:44 PM |
2010 Blue SS for $32990 and we pay for your plane ticket! | Mitsubishi in Syracuse | Dealer Camaros for Sale | 0 | 12-21-2009 12:42 PM |
