Old 07-14-2015, 10:43 PM   #1
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Need pics of wheels set up. 35mm offset, 5mm spacer with 315s
My current set up is 20x9 front and 20x10.5 rear 35mm offset running stock Pirellis at the moment. I have a 5mm spacer (could go down to a 3mm) on the rear right now bc the wheels are concave and do not clear the caliper. I'm wanting to go with 315/35/20. Is anyone running this set up? Can you post pics? I'm concerned how far this will stick out on the side of the car. I'm also lowered 1" front and 1.2" rear on eibach prokit performance springs.
Thanks!
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 07-19-2015, 05:53 PM   #2
oldfriend
Drives: Fiat 500 E
You can do that yourself with the setup you have
Just add two 5/16 spacers to your rear wheel outside face , one on the bottom section off the wheel and one on the top , get a strait edge from top to bottom on those savers and you will see what it will look like
