02-24-2024, 04:20 AM | #1 |
Drives: 2012 Camaro ZL1 Join Date: Aug 2020
Oil filter Numbers
Anyone bought oil filters lately ? Numbers on box does not match the one on the filters, these are from Rock Auto but a dealer here in Norway who stocks them say their inventory is the same 🤔
2012 ZL1 #428
02-24-2024, 05:35 AM | #2 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
That number 19433934 is actually PF48E.
https://www.camaro5.com/forums/showt...99#post8281699 This is the new "E-Core" design oil filter and is slightly shorter in overall length than the PF48. The E-Core design has the same amount oil filter media and better filtration than the previous filter. The Ultraguard UPF48R filter (U is for Ultra and R is for Racing) is black in color, has a thicker exterior shell. The internal components are the same in both the UPF48R and the PF48 oil filters. The UPF48R can be used in applications where the PF48 is specified. Btw. "GM requires the UPF48R for the LS9 application and is also used for the LS7 application as both engines are built at GM’s Wixom Engine Performance Build Center." Last edited by chevy pilot; 02-24-2024 at 06:17 AM. |
02-24-2024, 05:41 AM | #3 |
Drives: 2013 ZL1 Join Date: Sep 2021
The last AC/Delco I bought was like that-mine also said made in China. Possibly consolidating part #s. Returned it and got a Wix-also made in China:(
02-24-2024, 06:42 AM | #4 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Sounds like they cheaped out and used the old packaging on new the new filters.
They should have at least put a sticker on the box or a small note/disclaimer inside. The beauty of the internet is that it allows you to check applications on line so you can make sure it is right.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
02-24-2024, 06:40 PM | #5 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I purchased one and it looked just like the one you got, So I ordered another from somewhere else and it is like that one as well, Mine were always Black and Gold and came in a matching box, I thought the first was a knock off but then the I got the second just like it.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
