Old 07-25-2015, 08:03 PM   #1
Desmoines1LE
Drives: 2015 summit white 1LE
Am I to paranoid?
So I've owned my car since February 7th here in Des Moines Iowa, not even 5,000 miles on it and I've had two Mobil one full synthetic oil changes, royal purple transmission fluid exchange, Mobil one rear differential fluid exchange, high performance brake fluid exchange, two new rear 305/35/20 tires, and an alignment.. Anyone else as paranoid as I am as far as maintenance or is it just me?
Desmoines1LE is offline   Reply With Quote
Old 07-25-2015, 08:10 PM   #2
manganos
Drives: Lexus IS250 and BMW R1200GS
I hope to find an owner like you when I go to buy mine in March LOL
manganos is offline   Reply With Quote
Old 07-25-2015, 08:23 PM   #3
Desmoines1LE
Well thank you! I have always been that way with all my cars figured be safe than sorry
Old 07-25-2015, 08:31 PM   #4
ron10
Drives: 2010 2SS IOM L99
you are wasting a lot of money.
Old 07-25-2015, 08:53 PM   #5
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
I am in your camp...Changing fluids during break in will pay off in overall performance and life expectancy.
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 07-25-2015, 09:06 PM   #6
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Why did you need tires so soon?
There Is nothing wrong with maintaining your car but if you are draining out clean fluid to install more clean fluid then it's a wastemof money. I understand changing them during breakin and also if you are tracking your car but there is a limit between well maintained and wasteful.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 07-25-2015, 10:07 PM   #7
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
I'd guess if he needed new tires with under 5000 miles on his car, he dives it pretty HARD
skipinminn is offline   Reply With Quote
Old 07-26-2015, 02:02 PM   #8
Desmoines1LE
I'm tracking the car as much as possible. And wanted to catch the maintence and tires early rather than latter lol
Old 07-26-2015, 03:06 PM   #9
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
i need to change my differential fluid soon too. Maybe I will change them here when I drain my breakin oil for the new engine. What did you use Royal purple or mobile 1 for the differential?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
