Old 06-05-2011, 04:51 PM   #1
John Deere Boy
I bleed green
John Deere Boy's Avatar
Drives: '11 2SS/RS LS3
How do you close the trunk without touching the paint?
I've been closing it by putting my fingers on the bowtie. Hey, it's replaceable, right? But i just read that it's only glued on so that's probably not a good idea. So any of you guys found a way a good way to close it?
2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen.
2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE
John Deere Boy is offline   Reply With Quote
Old 06-05-2011, 04:53 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
I use the bowtie also, but it doesnt take much pressure to close the trunk so it should be safe enough.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 06-05-2011, 04:54 PM   #3
Rick 2000
Drives: 2011 LS
Same here
Rick 2000 is offline   Reply With Quote
Old 06-05-2011, 04:54 PM   #4
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
I touch the vinyl graphics or use my forearm instead of touching with my hand. Black paint shows fingerprints easy.
Inferno LSX is offline   Reply With Quote
Old 06-05-2011, 04:55 PM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I've used the bowtie for almost 20k miles without issue. My bowtie has the posts which may make it more solid though.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-05-2011, 04:57 PM   #6
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2010 Summit White Camaro SS/RS
use your palm, not your fingers.
gl2filmerguy is offline   Reply With Quote
Old 06-05-2011, 04:57 PM   #7
John Deere Boy
I bleed green
I think the oil from my skin will eventually eat away at the vinyl the same way it does with paint, plus there's no protective wax on the vinyl. (I'm thinking 10-20 years down the road here)
Old 06-05-2011, 05:00 PM   #8
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
I use a microfiber towel or the bowtie.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 06-05-2011, 05:05 PM   #9
NicksVSix
NicksVSix's Avatar
Drives: 2014 2LT Red Rock Metallic
Don't take offence, but I think you're being overly careful....just close it gently with your hand...you'll be fine.
NicksVSix is offline   Reply With Quote
Old 06-05-2011, 05:09 PM   #10
MORA84
MORA84's Avatar
Drives: 2010 CAMARO 1SS/M6 BLACK ON BLACK
Bowtie
MORA84 is offline   Reply With Quote
Old 06-05-2011, 05:21 PM   #11
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
It's a car....yes, a beautiful, unique car, a throwback to the '69 beast...but it's a car. Close it with your hands
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 06-05-2011, 05:26 PM   #12
Sunlover
Sunlover's Avatar
Drives: 2011 Camaro 1LT/RS
I use the bowtie, but if you're really concerned, you could add a slight modification to your trunk that I had in an old jag. It was a leather loop attached to the inside of the trunk lid, that you could pull down on to start the trunk closing, and pulled with the right force, it would totally close the trunk to a locked down position. It was very convenient.
Sunlover is offline   Reply With Quote
Old 06-05-2011, 05:27 PM   #13
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
I use the bowtie also.
IamJacksCamaro is offline   Reply With Quote
Old 06-05-2011, 05:32 PM   #14
mrcubbie16
mrcubbie16's Avatar
Drives: 10' RJT 2SS/RS Hennessey HPE600 #72
I use the black rubber stops on the underside of the deck lid.
mrcubbie16 is offline   Reply With Quote
A few questions about custom paint jobs. nardox Cosmetics and Lighting Modification Discussions 11 02-21-2011 08:34 AM
Red lights mean stop... Tessa 5th Gen Camaro SS LS LT General Discussions 84 06-24-2010 09:19 AM
Removing Swirl Marks using a Flex and Meguiars M105/M205 Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 05-22-2010 10:36 PM
Need Help on Paint Issues Agostino13 5th Gen Camaro SS LS LT General Discussions 12 10-08-2009 05:03 PM
