10-15-2022, 07:29 PM | #1 |
Drives: 2015 Camaro LS Join Date: Jan 2017
Tons of V6 Bolt ons for Sale: rotofab intake,EE catch can,Phastek intake scoop,etc
I supercharged my LFX Camaro so selling off things I can't use anymore. Message me if interested. I'll pay shipping so price below is all you'll owe me. Open to best offers as well.
Rotofab Intake - SOLD $220 Includes a dry Rotofab brand filter that requires no filter oil Elite Engineering Catch Can 2nd Gen W/ Air Oil Separator- SOLD $200 Phastek Intake Scoop with Windshield Washer relocator- SOLD $100 works with all aftermarket intakes except Airaid GM Brake Cooling Kit- NEW - SOLD $200 Hard to find these days, wouldn't fit with my intercooler (first world problems...) Should include everything you need except for this bracket (22943667) as I couldn't find anyone that had this, but shouldn't be hard to make your own. Also includes GM gen 6 track deflector kit which will work with Gen5, there's a guide on here for how to get this to work. Kit part list: 23480632 DUCT ASM-FRT BRK ROTOR CLG, 1 22943669 SPACER,FRT BRK ROT CLG DUCT,1 11547755 BOLT/SCREW,10 11570637 BOLT/SCREW-TRUSS HD W/SPL SHLDR,4 11589290 PIN - PUSH, FITS 6.5 HOLE,4.5 -7.0 THK P*JET BLACK,2 23480631 DUCT,FRT BRK ROTOR CLG, 1 22943670 SPACER,FRT BRK ROT CLG DUCT, 22943668 BRACKET ASM-FRT BPR FASCIA LWR,1 Other stuff I have if you need it: V6 Camaro gloss black hood with 3M paint protection film $350 - SOLD V6 Camaro front bumper with Z28 grille with flowtie, foglights, and 3M paint protection film $350 - SOLD 3.6L high pressure fuel pump,12691016, NEW $190 3.6L Low pressure fuel pump, used, 13592337, 60k miles on it, doesn't include fuel level unit, but you can easily swap the one from your pump to this pump $50 3.6L Direct Injectors 12634126 Set Of 6 for $100 (great if you want to send these off to be rebuilt so you'd have no downtime for your car) My Camaro drinks a lot of ethanol now so all proceeds go towards buying drinks for this thing living in my garage...
2015 LFX M6 LS:Rotofab intake,Vmax ported throttle body,Jacfab laminator FX,extendolator,ARH HFC downpipes,Magnaflow resonated X pipe,SLP LM2 catback,Solo J pipes,Overkill Flexfuel sensor,E85 tune,3.91 gears,Monster twin disc clutch,Michelin PS4S tires,FR ZL1 wheels,SS brembos,BP drilled and slotted rotors,HPS 5.0 pads,RST SS brake lines,BMR rear trailing arms,Hendrix solid rear cradle bushings,1" drop Hotchkis lowering springs,1LE struts and sway bars,oem strut tower bar,Pedders radius rod bushing insert and rear trailing arm bushings,Z28 upper control arm bushings
10-25-2022, 03:59 PM | #2 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
PM sent regarding the Brake cooling kit...
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
10-29-2022, 12:02 PM | #3 |
Catch can sold
Brake cooling kit still for sale
10-30-2022, 11:27 AM | #4 |
Rotofab intake sold
12-12-2022, 11:13 PM | #5 |
hood sold
front bumper sold brake cooling kit sold intake scoop sold
