Old 05-02-2013, 09:09 PM   #1
Chaotic73
BUMBLLB
Chaotic73's Avatar
Drives: 2010 Camaro 1LT/RS
TPMS not working
TPMS shows dashes for all tires and there is no option to relearn/reset. Does anyone know of a fix for this or had the same thing happen?
Chaotic73 is offline   Reply With Quote
Old 05-02-2013, 09:20 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
You have a 2010, so you can do the relearn yourself. It's like page 10-45 of your owners manual if I remember right.
Click to view my build thread
Old 05-02-2013, 09:31 PM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
If you have a stick, make sure it's in gear... The option doesn't show up while in neutral.
Sterling is offline   Reply With Quote
Old 05-03-2013, 09:27 AM   #4
Rizzo
Drives: 2012 Camaro ZL-1 SIM
I had a similar issue with two of mine. Turned out it was the Scosche kit for my aftermarket radio that was causing the issue:
http://www.camaro5.com/forums/showthread.php?t=246752
Rizzo is offline   Reply With Quote
Old 05-03-2013, 10:26 PM   #5
Chaotic73
BUMBLLB
Chaotic73's Avatar
The option to relearn is not showing up on the DIC.
Have an auto
Still have the stock radio.
Old 05-04-2013, 05:39 AM   #6
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Mine did the same thing, it turned out to be the module for the door locks and remote start (on the windshield), I had my windshield replaced, and when they did it, they pinched a wire, got it fixed and now it works.
warren3537 is offline   Reply With Quote
Old 05-04-2013, 05:45 AM   #7
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Drives: 2010 Camaro 2SS
It could very well be what warren3537 described, a quick TPM relearn will guide the technician in the proper direction. a quick module scan with his MDI can also pull up a DTC that is related to your problem, but I would start with a simple TPM relearn and go from there!
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators.
DJ_BigC is offline   Reply With Quote
