#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 04-22-2024, 06:35 PM   #1
italia366
italia366's Avatar
Drives: 2022 Camaro 2SS 1LE
Question Track day - Lug nut question
Hello!
Just got done with my first track day in the Camaro, and I absolutely love it. This is my 5th event total, but first with this car, and it is crazy how capable it is. Very, very happy with it!
No problems or issues thankfully, but I am encountering something I've not on my previous cars: my lugs need to be tightened before every session. I am on a OEM setup (minus Castrol SRF fluid), and am torquing the lugs to 140 lb ft with a 150 lb ft 1/2" inch drive torque wrench when the car is cooled down, so aka, right before a session. Surprisingly, several lugs around the car need to be tightened every single time, but especially my front left tire. My previous cars maybe has 1 or 2 that needed to be tightened over the course of a day , but never this many this frequently
Basically my question is - is this normal for the Camaro, and something you guys experience as well? Or, do I need to get a bigger torque wrench for better accuracy? I know torque wrenches typically aren't accurate at the low end of their range, but I wasn't sure if that also applied to the top end. Or is something else going on?
Thanks! Looking forward to day 2 tomorrow
italia366 is offline   Reply With Quote
Old 04-22-2024, 06:41 PM   #2
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I had that issue with some aftermarket lugs, haven't tried the oem lugs on track.
I installed longer MSI studs up front and got a set of MSI lug nuts, they've been great. Super high quality, well worth it for a track car.
DaveC113 is offline   Reply With Quote
Old 04-23-2024, 09:24 AM   #3
italia366
italia366's Avatar
Figured out it was an issue with my wrench, thankfully the car is fine!
Old 04-23-2024, 11:39 AM   #4
nasbagoat
Drives: 17 SW 1LE
Do not toque a hot car if you can avoid it. Once everything is heated up and you retorque, you are stretching the stud out and weakening/reducing its ability to return to size when you remove the nuts.
nasbagoat is offline   Reply With Quote
Old 04-23-2024, 03:22 PM   #5
cdrptrks
cdrptrks's Avatar
Drives: 2017 Blue Camaro 1SS 1LE with PDR
Not normal. I usually check torque before the first session (sometimes at home) with my 1/2" drive Harbor Freight torque wrench and often not again until after the event and I've have never had a single lug nut loosen significantly by itself.
I believe using aftermarket lug nuts with a smaller conical seating surface area than the stock lug nuts while using stock wheels could cause loosening while driving.
cdrptrks is offline   Reply With Quote
Old 04-23-2024, 05:33 PM   #6
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
That's very good to hear I never had any issue, but then I don't track the car, so that may not be relevant.
However, I do use and recommend a bigger torque wrench on these lug nuts. Mine has a 25 to 250 lb-ft range, because I don't think these wrenches are accurate enough at either end of their load range (heck, they may be off by a couple percent even in the middle). In addition, a larger wrench requires less effort to reach the desired torque, so human errors such as overtorqueing or tightening when the wrench is stationary can be minimized as well.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 04-23-2024, 06:36 PM   #7
nikerret
Drives: 2014 Ford F-350
Just another data point, my stock lug nuts haven’t backed off at all, from tracking. I don’t tighten after the first session, but I do check them at the start of every day (track days).
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30
2014 Hyundai Elantra GT
1995 Buick Roadmaster Estate
nikerret is offline   Reply With Quote
Old 04-23-2024, 06:59 PM   #8
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Glad you figured it out, definitely not normal.
Christian1LE is offline   Reply With Quote
Old 05-09-2024, 06:01 AM   #9
OneLapWonder
Drives: 2008 Audi RS4
UOM?
2012 Lexus CT200h Premium Navi
2008 Audi RS4
2004 Audi S4
2018 Chebby Camaro ZLE HMB
OneLapWonder is offline   Reply With Quote
Old 05-09-2024, 08:40 AM   #10
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
On track I run open end Ford Racing lug nuts - fairly inexpensive, well made and do not have overcap.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 05-09-2024, 10:29 AM   #11
USMUCL
Confirming that these lugs call for 140 ft/lbs?
USMUCL is offline   Reply With Quote
Old 05-09-2024, 12:11 PM   #12
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Correct! 140
Nothing like an SS is offline   Reply With Quote
Old 05-09-2024, 08:02 PM   #13
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
A certified calibrated torque wrench is always good practice, especially working on the smaller bolts with aluminum. accuracy is very important
CalgaryZL1 is offline   Reply With Quote
Old 05-10-2024, 11:33 AM   #14
USMUCL
Originally Posted by Nothing like an SS View Post
Correct! 140
thx
