11-10-2023, 06:34 AM | #15 |
Drives: 2013 ZL1 Join Date: Sep 2021
You seemed to get your feelings hurt when people were just trying to help you. Two bad thermostat housings is very unlikely. Even though the repair is under warranty do you really want them working on it again? I would chance it and have someone else look at the car and have them diagnose the leak. If it is another problem ask for a refund from the original shop-you did get the old housing back didn't you? A quick look should see any crack or corrosion on the flange. For a full refund they will want the replacement housing back.
11-10-2023, 08:46 AM | #16 | |
David Vianu
2010 Synergy Green 1LT Last edited by 2010sgm; 11-10-2023 at 08:57 AM. |
11-10-2023, 08:46 PM | #17 | |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Being a 40 plus year automotive technician I’ve tried to give good advice to members that may not know what to do or test check etc…. I’ve also learned a lot from this great 5th gen site. The camshaft I’ve installed, the torque converter etc. This forum is great. I just snapped when I read that. Members just trying to help and gather more information |
11-11-2023, 03:02 PM | #18 |
I can tell you from experience Carvana puts band aids on repairs they probably put stop leak in your system instead of replacing the housing.
Go to Ebay or Amazon and look up coolant dye and also pick up an inexpensive black light. Put the dye in and run the engine for a bit and see where its actually leaking-you may have to wait until dark if you don't see anything. Once you see where its leaking you can go from there. |
11-11-2023, 04:15 PM | #19 | |
David Vianu
2010 Synergy Green 1LT Last edited by 2010sgm; 11-11-2023 at 06:37 PM. |
11-13-2023, 06:45 PM | #20 |
Had nothing to do with housing he heater pipe has two pin holes in the metal that swell when it gets hot. We pressure tested etc all with no issue until we ran it and got it hot then we found the leak.
David Vianu
2010 Synergy Green 1LT |
11-13-2023, 07:07 PM | #21 |
Awesome!! Glad you found it!!
11-20-2023, 08:41 PM | #22 |
The rusted parts all fixed all new hos3s on car and no leaks
David Vianu
11-20-2023, 11:45 PM | #23 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
Well that's good, but wow
11-21-2023, 04:24 AM | #24 |
Look like water accumulated over the years considering this car is not driven in rain or snow should be good for years to come...changed all hoses at same time so we are good!
David Vianu
11-21-2023, 05:11 AM | #25 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Just an FYI-
GM's been putting stop leak tablets in the coolant systems at the factory for DECADES. GM service centers also are recommended to use them when replacing new engines and radiators, etc., as a preventive measure. Just sayin'. Anyone who says they'll never use stop-leak tablets likely already has.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-21-2023, 05:24 AM | #26 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Glad you got it sorted, and didn't require major repair.
11-21-2023, 11:19 AM | #27 | |
David Vianu
12-27-2023, 08:16 PM | #28 |
So after a month its leaking again and now its leaking at the water outlet/coolnat fill on the block. We put uv dye in the dexcool to verify norhing is leaking at the housing which is dry. Seals changed lets hope this solves it....
David Vianu
