11-11-2014, 03:31 PM | #1 |
Silver Ice
Broken glass in rear speakers
So a few months ago(If you see my posts you'll know i have bad luck with everything that has to do with my car), my Camaro was vandalized.
Was luckily covered by insurance with no deductible. But still Annoying. What wasnt covered was the broken tail light and the annoying pieces of glass rattling in the rear speakers. Anyone know an easy way to get the broken glass out? Or am i going to have to disassemble the entire back of my car to get out the glass? Thanks for your help. |
11-11-2014, 03:39 PM | #2 |
Drives: 2012 Corvette Grand Sport Join Date: Jan 2011
I would think a shop vac would help.
Casper is a 2012 Corvette Grand Sport w/ Heritage package.
11-11-2014, 03:41 PM | #3 |
Silver Ice
Forgot to mention. I tried all the obvious stuff. Went to high powered vacs they have at the nice car washes. It got some out after a few tried, but there are some pieces still left in there :/ Any bass and it sounds like a volcano erupting from the rear speakers.
11-11-2014, 03:53 PM | #4 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Don't the speakers come out through the trunk? That would be the best way to make sure to get them all out. Or you could take the car to a stereo shop and have them upgrade your speakers.
The Bird is the word! |
11-11-2014, 03:57 PM | #5 |
Silver Ice
I Looked at them and also searched the web. Couldnt find a way to drop them through the trunk. I was hoping someone on here would have input.
11-11-2014, 04:15 PM | #6 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
He's right drop them from the bottom should be 4 bolts on each corner. If my trunk wasn't full I would take a look.
11-11-2014, 04:17 PM | #7 |
Silver Ice
Thats awesome. Ill take another look tomorrow morning when i have some light. I really hope you guys are right. Bass all the way down makes radio sound odd.
11-11-2014, 04:18 PM | #8 |
Not that easy from what I`ve read, you have to tear out the whole back area to get the speakers out I`m pretty sure.
11-11-2014, 04:19 PM | #9 |
Silver Ice
11-11-2014, 04:22 PM | #10 |
I would try compressed air but be careful not too much pressure or you may damage the speaker.
11-11-2014, 05:38 PM | #11 |
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox Join Date: Apr 2013
You need to take a lot apart. To get the deck lid off you need to remove the side pillar trim in the back seat. Speakers come out the top not the bottom unfortunately. Would be much nicer for replacing the stereo I'll tell ya. You could gut the speakers and remove them from the bottom and replace them though. You would end up destroying the speakers that are there. There is only one bolt that holds them in you could punch it out from the bottom. This is a very brute way to do it and I wouldn't recommend doing it since gutting the speakers could put more things to rattle around up in there, but you would gain access to the space and theoretically get a shop vac in there.
If you want it clean in there its all gotta come apart. If you don't have time you could ask a stereo shop to clean out in there for you. They are fast at removing panels and such, and a relatively cheap shop rate. Even though they aren't installing speakers they may still do it if you are nice enough about it. I would replace the speakers and dynamat while its apart anyway. By the way if it was covered under insurance, they should be recommending a shop to clean it out.
11-11-2014, 06:18 PM | #12 |
Silver Ice
Good Idea! Worse case i wreck these speakers and have to replace them. Which I would be doing regardless if I had to go through the rear speaker removal process anyways..
11-11-2014, 06:37 PM | #13 |
Drives: 2010 SS/RS Join Date: Nov 2014
Play some bassy music, shop vac the speakers with them playing. Eventually you should hopefully get everything.
11-12-2014, 03:19 AM | #14 |
Drives: 2010 Inferno Orange Camaro Join Date: Mar 2011
Had the same problem after mine got wrecked from a hailstorm. Turning up the volume and vac is how I got mine back to normal
