Old 11-26-2014, 10:48 PM   #1
Dee Money 916
Dee Money 916's Avatar
Drives: Looking for 1LE. . .
Does this void warranty?
Hey guys, does taking off the 4 freaking resonators void your warranty?
I want to go with headers and a full exhaust, but I don't want to void my warranty, I paid extra for the extended too....
Your knowledge helps,
Thanks!
Tight Lines
Dee Money 916 is offline   Reply With Quote
Old 11-26-2014, 10:53 PM   #2
hworth18
Jus' Cruzin
hworth18's Avatar
Drives: 2017 Camaro 1SS Krypton Green
it will void your exhaust/emissions warranty, but not your drivetrain
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark
hworth18 is offline   Reply With Quote
Old 11-26-2014, 11:12 PM   #3
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Except, from what I understand when you put on headers yu will get a CEL and to fix it you need to do a tune. The tune will void your engine warranty IF they can prove it relates to the failed part.
Eg. 1- Burn a piston and they see the computer perameters have been changed so VOID.
2- Nav. Head goes blank so jothing to do with tune and warranty is good.
If it makes you feel any better I'm in the same boat. My car is my DD and I got the extended warranty. I've added a CAI and may do a couple other minor mods like a ported TB, etc. so my warranty is still solid.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 11-26-2014, 11:20 PM   #4
SIM Curly
SIM Curly's Avatar
Drives: Silver 1LT 2011 camaro
Just buy a bluetooth code reader and clear it whenver it comes up takes like 2 seconds and only comes back every now and then if your're worried about the check engine light.
SIM Curly is offline   Reply With Quote
Old 11-27-2014, 02:14 AM   #5
Dee Money 916
From adding the CAI have you noticed a difference in anything?
And I'm not one to mess with CEL, that worries me. Lol... I'm paranoid like that...
To me my car is too quiet, I want it to sound like the beast it is. I have added exhaust (just cat backs though). They sound ooookkkk, but I want a deeper growl!
Any suggestions my fellow maro owners???
Tight Lines
Old 11-27-2014, 06:02 AM   #6
SCREAMING EAGLE
SCREAMING EAGLE's Avatar
Drives: 2012 CAMARO 2SS 45TH,L99
Tight Lines
GET A BORLA ATAK OR S TYPE AXEL BACK EXHAUST. tO ME NOTHING SOUNDS BETTER THAN AN S TYPE.
SCREAMING EAGLE is offline   Reply With Quote
Old 11-27-2014, 10:58 AM   #7
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
No it won't, good read:
Will This Modification Void My Warranty?
BigBlock69RS is offline   Reply With Quote
Old 12-04-2014, 03:58 PM   #8
strutton
SStrutt
strutton's Avatar
Drives: 2014 Camaro 2SS/RS Convertible L99
Try high flow cats from Solo. I added that with their cat-back exhaust. Sounds incredible and no CEL. I'm adding CAI soon.
strutton is offline   Reply With Quote
Old 12-04-2014, 04:55 PM   #9
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Here in Louisiana, the vehicle will not pass inspection, it will come up as OBDII is busy or all test not complete.The computer could also have a stored code. It might be different where you live.
Old 12-04-2014, 05:01 PM   #10
Ragnar
Ragnar's Avatar
Drives: Wife's car
How many miles have you driven? Check out the thread on Solo High Flow cats in the Camaro LS3 / L99 section.
Old 12-04-2014, 05:16 PM   #11
Ragnar
Ragnar's Avatar
Drives: Wife's car
OP, here is a suggestion, add a Bo White throttle body with a CAI and it will make you go 'WOW'! The throttle response has no lag, it will be so much better. I wish that I would have done those mods months ago. You can find information in the LS3 / L99 section. No check engine light with these mods.
Old 12-04-2014, 06:12 PM   #12
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Hey guys, does ______ (fill in the blank) void your warranty?
Such a commonly asked question that is often hard to definitively answer. Technically (and theoretically) anything you do to your car that changes the original configuration could void certain warranties. Removing resonators will likely not void your engine/powertrain warranty if you have an issue, but if your cats quit working (for example)I'm pretty sure GM will void your exhaust system warranty. If they can prove anything you have done has caused your specific problem, your warranty on that particular part/system/etc will likely go down the tubes.
For example: if you add show lights (or whatever you call them) and your wiring system overheats and burns up your car... you're screwed.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 12-04-2014, 06:12 PM   #13
strutton
SStrutt
strutton's Avatar
I'm sure I'm at least over 500 miles maybe 1000. Just read the thread seems like there's a solution to the CEL if you get them... Thanks for the the info!
Old 12-04-2014, 07:16 PM   #14
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Thanks!
Tight Lines
Long tube headers will not pass visual smog test in California...
jeffa is offline   Reply With Quote
