01-14-2024, 09:02 PM | #1 |
Drives: '22 2SS 1LE Join Date: Nov 2023
The Man speaks on street E85 reliability
sludge @ 4m |
01-16-2024, 08:37 AM | #2 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
That video is misleading... The sludge is from lack of maintenance and or the engine not getting up to operating temperature to burn off moisture. He claims 2000 miles the oil was changed but I don't believe it. Oil doesn't get that nasty in a healthy engine if changed every 2000 miles. I have been running E85 since 2017 and my engine nor any other engine I have seen looks like that after extended E85 use.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
01-16-2024, 10:42 AM | #3 |
Petro-sexual
I'm fairly certain that the OEMs wouldn't be supporting E85 in some of their products if there was a plague of problems as this thread seems to imply.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
01-16-2024, 11:23 AM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
At the beginning of the video he mentions that they used an oil additive, but never said which additive they used. I wonder if the additive caused or contributed to the sludge.
01-16-2024, 11:30 AM | #5 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
FWIW - since GM produces a lot of trucks and SUVs that are FlexFuel capable, just about all, if not all, small block V8 are FlexFuel prepped (hardened valves and seats) Not certain about the fuel pumps and fuel tanks though. I run E85 almost exclusively on my Camaro.
2017 CAMARO FIFTY SS CONVERTIBLE
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
01-16-2024, 12:28 PM | #6 |
i'm no expert, but he does mention increase wator vapor creation. if you're not burning it off sufficiently, i don't see what you could possibly "design" differently to mitigate the harm it causes. IOW, it seems like a general rule of thumb not to put around on E85 regardless of how well your lines and such can handle the corrosive properties of it simply because of the add'l water.
fair point on the oil additive not being mentioned. i dont have reason to doubt him on the oil changes, though his daughter was driving it and probably lugging the hell out of it. iono tho |
01-18-2024, 11:43 AM | #7 |
But it's On Youtube so it must be true.
www.jannettyracing.com
01-18-2024, 11:46 AM | #8 |
motoiq has been around forever. they're very credible. i have no doubt it *is* true....given his premises. there are variables, to be sure, that prevent his experience from being universal, but it's a valuable data point nonetheless. i.e. its probably not a good idea to DD w/ short trips on E85. at least, that's my takeaway. i'd totally love to hear what equipment the LT1 has that invalidates that general takeaway. |
01-18-2024, 11:53 AM | #9 | |
I would have wanted to see that engine disassembled before the test. I expect to see the same thing due to operating conditions, service intervals and other factors that would produce the same amount of sludge. The high compression in the LT Works extremely well with E-85. Ring seal, is a big factor on oil contamination along with PCV efficiency.
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 01-20-2024 at 08:51 AM. |
02-15-2024, 01:39 AM | #10 |
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man Join Date: Aug 2015
I have seen ugly oil on cars that we have built and get moved around the shop often over a long period of time. This is almost certainly a result of not reaching operating temperature. Depending on driving distance and weather condition some cars seem to require oil changes every 2k miles. Coyote Mustangs will have fuel pump failure if you don't put a fuel lubricant in the tank. Some have even reported high pressure pump and injector failure. If a Ford dealer is made aware of E85 use they will void all fuel system related warrenty claims.
02-15-2024, 03:02 PM | #11 |
interesting. did not know that. makes sense.
02-16-2024, 07:26 AM | #12 | |
Petro-sexual
Regardless - I use E' fuel stabilizer, and hopefully it does what it says it does.
02-17-2024, 01:07 AM | #13 | |
I'm semi-retired but have a shop ZMOD/Zehring Motorsports in Rancho Cordova. I have a dyno jet 224LC and tune late model GM and Ford. Spent many years racing 10inch tire drag cars, fastest streetcar series PSCA/WCHA/Vegas Streetcar Super nationals before street outlaws was popular. We won 8 of 10 championships and were the first to into the 7's at over 200MPH at 3400#'s on a 10 inch tire. Also went 5.88 261 in a twin turbo 69 Camaro. Here is an embarrassing video where I got caught sleeping at the tree but set the record in a final round 20k to win race.
02-17-2024, 08:05 AM | #14 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
That video is very misleading and pretty much BS.
GM Gen V Calibrator
