07-23-2019, 07:01 PM | #1 |
Drives: 2019 2ss 1LE Join Date: Mar 2019
Best exhaust option
Hey guys, was wondering what I can do to get a little more sound out of the exhaust while maintaining warranty, still having control of the dual mode, and still being able to pass inspection. I do not want headers.. thanks guys
07-23-2019, 09:06 PM | #2 |
Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
Borla S-type. Not too loud until you want it to be, good quality and sounds awesome. You will retain all exhaust controls. I have it on mine. Before installing, I had the entire system ceramic coated. Helps with heat and looks great.
07-23-2019, 09:33 PM | #3 |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
It looks as pretty as it sounds!!! Very nice
07-23-2019, 09:44 PM | #4 | |
What is the exact system you have? Im going to go with that |
07-23-2019, 09:45 PM | #5 |
07-23-2019, 09:54 PM | #6 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Looks like yes, just the mufflers. I would get the ATAK for the loudest sound possible. Part number 11925.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
07-23-2019, 09:55 PM | #7 |
Thank you Elvis66. It is the Borla s-type full catback #140-726 for the ZL1. Not sure if an SS takes a different kit. The system comes bare stainless steel. I had the catback and factory cats ceramic coated as well to match. The cat back is ceramic coated in two different colors. Silver for the front section/factory cats and black for the rear section. I did black to make the mufflers and tailpipes less obvious and the black does not require to be baked on. Baking the tail pipe sections would damage the return springs that operate the exhaust valves. The actuators open the valves but the spring to close them is part of the tailpipe.
07-24-2019, 12:35 AM | #8 |
Drives: 2017 2SS Camaro Join Date: Mar 2015
I have the s-type (#11924). love the sound, louder than stock but only obnoxious when your really on it. Maintains NPP adjustability too. Pricey, but worth every penny.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
07-24-2019, 02:39 AM | #9 |
Drives: 17 SS 1LE Join Date: Dec 2015
For NPP get Flowmaster if you like a deep sound and Borla if you like a throaty sound. The other systems don’t seem to have a very effective quiet mode.
07-24-2019, 04:35 AM | #10 |
Drives: 2019 1LE Join Date: Jul 2019
Any check engine lights with the Borla S-Type???
07-24-2019, 06:30 AM | #11 |
Drives: 2019 camaro Join Date: Jun 2019
just remove the 2nd set of cat's it will sound alot louder. that wont void your warranty and unless your in cali i doubt anyone will ever look or say anything. /shrug best change in sound you can do for the cheapest price.
07-24-2019, 07:09 AM | #12 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Any axle back will give you more sound. My V6 was way too quiet so I just installed the MBRP axle back. Just right now and it was so easy to install. It's your choice which one to go with. Read the posts and listen to the videos.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
07-24-2019, 09:29 AM | #13 |
Only if it's not installed correctly.
'16 Camaro 1SS
07-24-2019, 11:48 AM | #14 |
Drives: 2016 1ss camaro Join Date: Feb 2016
afe power makes axleback that works with npp i have it works great
