03-29-2012, 01:46 PM | #1 |
Drives: 2010 Camaro SS Join Date: Apr 2009
a few questions concerning the Metra Kit
Hey guys,
I need a double din in the camaro, the stock radio is just terrible. I have a few questions concerning the metra kit if anyone can answer them for me. 1- Does the Metra kit really retain all steering wheel functions? 2- Does it retain the stock USB hookup and microphone for phone use? 3- Does it retain the rear parking sensors? Those are the 3 main things I'd like to know before pulling the trigger. Any help is greatly appreciated! Thanks!
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
03-29-2012, 02:17 PM | #2 |
Car Enthusiast
Drives: 2010 Rally Yellow Camaro 2SS A/T Join Date: Dec 2010
.. i can answer on Scoshe ji ji ji Its not what you asked but you can use it to compare.
1- Does the Metra kit really retain all steering wheel functions? Scosche retains SWC. New model radios may not work as is the same case for Metra 2- Does it retain the stock USB hookup and microphone for phone use? Scosche is a dash kit.. not a radio. So those options would have to be compatible with your radio. I have a kenwood and i can retain the USB that came with the car by using a USB to mini adapter I did however use a different MIC for my bluetooth. 3- Does it retain the rear parking sensors? Scosche retains these with its own speaker. Hope this helps you to compare.. happy shopping !
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016 |
03-29-2012, 02:24 PM | #3 | |
Black is BACK
Drives: 2010 Blk on Blk 1LT Join Date: May 2010
The Black Pearl
03-29-2012, 03:02 PM | #4 |
Doc
1- Does the Metra kit really retain all steering wheel functions? Yes, it does
2- Does it retain the stock USB hookup and microphone for phone use? I do know the microphone is still functioning...I'm pretty use the USB works too. My DD headunit had two USB's so I used those over the stock USB...but its still in the center console 3- Does it retain the rear parking sensors? yes it does...I hate them...I prefer using my rear view camera over the sensors.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
03-29-2012, 03:28 PM | #5 |
Drives: 2010 Camaro SS 2SS Join Date: Mar 2010
Installed the metra kit with Kenwood TV unit...Fit * Finish excellent...Retained SWC...Only thing went to GM garage for service they disconnected battery...Seemed to have lost SWC...Everything else fine...People are telling me to just reprogram and everything will be fine...Esthetics looks much better than stock...
03-29-2012, 03:37 PM | #6 |
Car Enthusiast
you will probably need to hit search and type metra problem. Cause Kendell347 says there are no issues with SWC but i read somewhere else that new kenwoods were not working either just like scosche. Maybe you should specify which DD are u using
03-29-2012, 10:09 PM | #7 |
Thanks gang appreciate it!
03-30-2012, 06:08 AM | #8 |
I am using DDX419 unit...Haven't sat down yet to reprogram...Hope that works...Everything else with unit is A1...
Similar Threads | ||||
Metra Kit - Carbon Fiber & Other painted colors | Kunihiro | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 02-03-2011 10:23 AM |
metra kit install questions | 99prbms | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 9 | 01-25-2011 06:41 AM |
wiring of metra kit | 1baer | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 0 | 12-05-2010 04:00 AM |
Metra Kit Issue? | phenixdragon | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 26 | 07-18-2010 01:42 PM |
