Old 05-31-2015, 12:55 PM   #1
Jake1212
Jake1212's Avatar
Drives: Black 2014 2SS 1LE
Swirl and scratch removal and coating.
Size:  195.1 KBYesterday I set out to remove some swirls and scratches from the paint. Took about 5 hours to get the car to the point I was happy with. I used the Adams correcting polish and finishing polish with the Orange and white foam and microfiber pad kit and it was a breeze. After the polishing was complete I used the blackfire paint coating to seal it all up and man does it shine now.
2014 Black 2SS, RS, 1LE, NPP, RECAROS
Jake1212 is offline   Reply With Quote
Old 05-31-2015, 01:44 PM   #2
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
Good work! Are you going to wax it too, or just leave it sealed?
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 05-31-2015, 01:46 PM   #3
Jake1212
Jake1212's Avatar
Before
Old 05-31-2015, 01:47 PM   #4
Jake1212
Jake1212's Avatar
After
Old 05-31-2015, 01:52 PM   #5
Jake1212
Jake1212's Avatar
The coating is like the cquartz or gtechniq coatings so i don't think I need to wax it.
Old 05-31-2015, 01:53 PM   #6
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
Waxing the coating will remove the cleaning abilities of the coating.
Iomcamaro is offline   Reply With Quote
Old 05-31-2015, 02:03 PM   #7
CruisingSpeed
The Stealth Bumblebee
CruisingSpeed's Avatar
Drives: Black 2013 2LS
What kind of water spots are those?
KILLER BEEhttp://www.ferrarilife.com/forums/attachments/modern-v8s-360-f430/51795d1353344804-f430-yellow-calipers-imageuploadedbytapatalk1353344802.106093.jpg
CruisingSpeed is offline   Reply With Quote
Old 05-31-2015, 02:22 PM   #8
Jake1212
Jake1212's Avatar
Thanks for the heads up iomcamaro I won't be putting anything on it now. And I have no idea what kind of spots. i guess the Rain and salt air mixed with afternoon sunny showers that we get here just burned spots into it all of the horizontal surfaces that water would sit on.
Old 05-31-2015, 02:27 PM   #9
str8wick3d
Drives: 2011 Camaro SS
From the looks of it, this is exactly what I need to do. I have tiny scratch's in the clear coat from coin operated car wash brushes, and it look absolutely horrible in direct sunlight. Can you link the products you used?
str8wick3d is offline   Reply With Quote
Old 05-31-2015, 02:27 PM   #10
str8wick3d
http://adamspolishes.com/shop/adam-s...ng-polish.html is this what you used?
Old 05-31-2015, 02:32 PM   #11
Jake1212
Jake1212's Avatar
http://www.autogeek.net/blackfire-cr...t-coating.html
http://adamspolishes.com/shop/exteri...olish-kit.html
http://www.autogeek.net/blackfire-paint-prep-spray.html
Old 05-31-2015, 09:35 PM   #12
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
What did you use to prep the surface before the coating?
Looks great btw!
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 06-01-2015, 10:30 AM   #13
Jake1212
Jake1212's Avatar
I used the blackfire paint prep spray recommended for the blackfire crystal coat.
Old 06-01-2015, 06:57 PM   #14
ihaveacamaro
I like teeth.
Drives: #198
Very nice! That stuff is easy to work with! I really like it!
