04-09-2012, 07:41 PM | #1 |
Drives: a Join Date: Dec 2011
Scosche/Alpine kit questions and recommendations
Hello all. I'm planning on replacing the factory radio in a 2012 Camaro but before I did that I wanted to get some recommendations along with a better idea of what exactly was needed and any possible downsides. I've read a lot of threads and seen some mention of some issues that may come up but wanted to just make sure.
So I suppose for recommendations (I was really hoping to spend about $1k or less). I saw some different options but wasn't sure if there was anything cheaper. So what I'm looking for was: 1. Backup camera support 2. GPS support (not the Garmin iPhone app. An actual GPS) 3. HD radio (nice but not required if it makes a large jump in price) 4. Bluetooth (Both Handsfree and streaming (A2DP)) 5. XM 6. Onstar 7. Steering wheel controls Now on to the most important part. What all I would need. I just want to make sure I take everything into account. 1. Scosche kit (obviously) 2. Radio (again obvious) 3. Backup camera 4. Onstar module for the radio 5. Steering wheel control module (I saw an alpine kit on crutchfield which supposedly had this included. I'm just assuming that's based solely on the radio?) 6. Antenna adapter (Included with the kit? Or is this separate?) Now the questions: 1. The shark fin XM antenna. Is there an adapter that would allow you to use that or would you have to run a different antenna? (Such as this http://www.myradiostore.com/antennas...gm-single.html) 2. The factory microphone. Can you use that? It seems as though you have to use the one that comes with the radio. How big are those generally? Best place to put them? 3. You can't control the Onstar volume except with the sterring wheel controls correct? 4. Are there any other little quirks or gotchas? 5. Recommendations for the best prices? Crutchfield only seems to have the Alpine kit which is a little more than I wanted to spend but some ideas on what works best would be awesome. DoubleD Mods seems to have a good selection as well along with all the required parts (I think). Basically any thoughts, inputs, and experience would be appreciated. I just want to make sure I know what I'm going to get myself into before I put the money down. Thanks in advance. |
04-09-2012, 07:53 PM | #2 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
alpine 910 and perfect fit kit covers everything you need. questions 1-3 are no I'm pretty sure from what we found with mine. We didn't really try either, but by wiring diagram, I say no.
-John S.
04-09-2012, 07:59 PM | #3 | |
Also looking at the specs on crutchfield for the 910 it has bluetooth for the hands free but doesn't support bluetooth audio streaming (http://www.crutchfield.com/p_700CMO9...12#details-tab) Last edited by MrFreeman; 04-09-2012 at 08:10 PM. |
04-09-2012, 08:43 PM | #4 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
I'll try to answer some questions for you.
Now the questions: 1. The shark fin XM antenna. Is there an adapter that would allow you to use that or would you have to run a different antenna? (Such as this http://www.myradiostore.com/antennas...gm-single.html) 2. The factory microphone. Can you use that? It seems as though you have to use the one that comes with the radio. How big are those generally? Best place to put them? 3. You can't control the Onstar volume except with the sterring wheel controls correct? 4. Are there any other little quirks or gotchas? 5. Recommendations for the best prices? Crutchfield only seems to have the Alpine kit which is a little more than I wanted to spend but some ideas on what works best would be awesome. DoubleD Mods seems to have a good selection as well along with all the required parts (I think). With any radio you my have to buy an XM adapter for the XM radio to work. 1 yes that will work with the Camaro XM antenna but you will loose signal strength. It is not as strong as the XM antenna. 2 I have not read about any one using the onstar microphone. They are about 3/8 in diameter and about 1 in long. I have mine next to the rear view mirror. 3. No you can not control the Onstar volume using the radio just the steering wheel control. Google the radio you want to buy and you will find a lot of places that are cheaper the Crutchfeild. When you buy the Scoshe/Alpine dash kit make sure it has the newest software and firmware. The old software and firmware the steering controls did work allong with some other problems.
Caddy
04-09-2012, 09:23 PM | #5 |
instigator
yup...what caddy said. I dislike satellite radio. lol So I don't use it. I hid my alpine mic up off the headliner above rear view mirror. That's in the black area off windshield.
-John S.
04-10-2012, 03:16 PM | #6 |
I installed the Alpine 910 in my car. I do have a backup camera installed, gps, no on the HD radio and I finished it off with the Alpine dash kit
04-10-2012, 06:20 PM | #7 |
So for the Mic I guess the best place is by the rearview mirror. I may wind up using the actual XM antenna if it makes a huge difference. I'll test it out. Does it look like all the parts required are covered or am I missing anything? At least anything obvious?
Any other radio recommendations? Preferred sellers? |
04-10-2012, 06:47 PM | #8 | |
This my test area. This the way I take to my daughters house. 1 About 10 miles of normal city driving. 2 There a road that goes threw Fort Lewis and it about 10 miles long. It set up as this woods the 5 ft after railroad tracks then about 20 ft of clear area. Then a 2 lane road and then 5 ft then woods again. 1 I was using a Stratus 6. city driving no loss of signal. The Fort Lewis I lost signal about 6 times for about a sec. 2 I got the Xm to Sirius adapter and tried that using the pioneer radio. city lost signal 1 time. Fort Lewis about 12 times for 1 to 3 seconds. In one area lost signal for about a 1/2 mile 15 seconds signal lost. 3 switched back to the Sirius antenna using the pioneer radio. I lost signal about less the 1 sec. for the 20 mile trip. I left it using the Sirius antenna. The Camaro XM antenna may work ok if you not in a very wooded area, tall buildings.
Caddy
Similar Threads | ||||
Water/Meth kit questions? | Beescuz | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 02-19-2012 10:18 PM |
GRIP Tuning 2010+ Camaro SS Body Kit and components! | Grip Tuning | Exterior Parts & Accessories | 2 | 02-19-2012 12:13 PM |
For Sale: Patriot Gold Double Spring Kit .650 Lift!! | ztsmith86 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 3 | 02-17-2012 06:22 AM |
Vengeance Racing Cam Kit Plus And Cam kit Plus Conversion | Kevin@V | Engine Internals | 0 | 12-08-2011 10:05 PM |
Install of new Pioneer AVH-P3300BT with painted black Metra kit | Darth Martel | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 50 | 09-13-2011 08:50 AM |
