05-08-2024, 03:33 PM | #1 |
Drives: Chevy Camaro Join Date: Apr 2022
Shift to park
Greetings all,
Is there anybody that has experience with this error message? My 20’ camaro SS has a message every now & then saying “shift to park” when I cut off the car. In order for me to get it to clear I simply depress and release the silver button (gear selector) I’ve looked online & saw Malibu’s, Acadia’s, & other GM vehicles have this issue. I watched a video on a Acadia with the issue, the guy removes the bezel to the gear selector, pops out a little black tab, & bends a pressure switch and that resolves the issue. I tried to do that on my Camaro, but I could not locate a black tab to bend the switch. Any help would be much appreciated! Thanks.
05-08-2024, 03:37 PM | #2 | |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
05-08-2024, 03:40 PM | #3 |
Yea, it’s just annoying, I’ll get it figured out though… How is the torque in Zl1?
05-08-2024, 03:55 PM | #4 |
05-09-2024, 04:45 AM | #5 |
05-09-2024, 08:51 AM | #6 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
There is a recall with this but for some reason does not include the Camaro SS. Internet is littered with this complaint for camaro ss. Kinda bothersome. Right now I feel like I'm playing Russian Roulette. Obviously I have no warranty, and I really want to see how they will explain aftermarket mods caused the issue.
I don't have the problem yet...
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
