11-19-2011, 01:10 PM | #1 |
Weld Racing RT-S
Fed Ex delivered my new 17" Weld RT-S wheels yesterday that I bought from McCormack Racing (see my review in the vendor feedback section). Yes, these are the 17x10 and 17x5, as recommended in the Weld fitment guide. But just wanted to say that I am thoroughly impressed with the quality and craftsmanship of these wheels. They look awesome!!! Initially, Weld Racing told me their RT-S wheels were not compatible with TPMS systems, but I discovered that if I used a Dill Air Controls all-metal valve stem (P/N VS-925C) and flipped the sensor upside down, it works great!! I can see that I will definitely need to tie back the emergency brake cables in the rear. And hopefully, I won't need to notch my rear LCA's if I keep my rear ride height at or above OEM height. I plan on getting the new BMR adjustable LCA's when my budget permits, but that probably won't be for a while. As it sits right now (suspension fully extended), I have about 3/4" between the rear LCA and the inner lip of the wheel. Just thought I'd share some pictures and say that I am very happy with my decision to go with the Welds.....(so far). NOW I JUST NEED TIRES!!!
11-19-2011, 02:18 PM | #2 |
Boosted Moderator
Those look amazing... I've been looking at Weld wheels....
Do you know if this or a similar style is available in a 16 inch by say 10 or 11 inch wide wheel... I'll replace the rear brakes...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
11-19-2011, 02:37 PM | #3 |
Thanks for the compliment. Unfortunately, the RT-S wheels are not available in 16", they jump from 15" to 17". I think Bogart is the only manufacturer that makes a 16" that fits with the V6 brakes. Maybe CCW too?!?!?
11-19-2011, 02:48 PM | #4 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Those look great. How much clearance around the Brembo calipers? I thought 18's were the smallest you could go.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
11-19-2011, 03:06 PM | #5 |
those are going to look awesome
11-19-2011, 05:19 PM | #6 |
Nope, 17" is as small as you can go without changing the brakes, but I think Weld and Bogart are the only 17's that will fit. To answer your question, I have about 1/4" between the outside of the caliper and the inner barrel of the wheel, and probably about 3/8" between the front face of the caliper and the back of the spokes on the wheel. However, If you're lowered at all, you will need to either notch your lower control arms or buy BMR's new LCA's which have pretty much been designed to be compatible with these exact wheels.
11-19-2011, 05:51 PM | #7 |
Drives: 2SS/RS Join Date: Apr 2010
I have these same wheels on the back. My car has Eibach lowering springs. Droppd maybe 1 1/4". Still running unmodified stock lower control arms. E-brake cable tie down was the only mod needed. Thanks for pics, i need to order the front wheels next. That thing will look awesome!
438cid IPS Twin Turbo.
11-19-2011, 06:47 PM | #8 |
Drives: 2010 IOM 1SS M6 Join Date: Jun 2011
I love those wheels. Thanks for posting pics!
11-19-2011, 06:55 PM | #9 |
Yep, CCW will make a set. Same ballpark as the Bogarts. I really wish Weld would step up and offer a 16" for the rear. Plenty of Bias Ply and Radial tire choices in a 16".
11-19-2011, 07:37 PM | #10 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Couple questions if you don't mind. What is the weight and what is the cost? Thx
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
11-19-2011, 08:17 PM | #11 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
the weld wheels are nice but if your lowered and leave the line hard they will hit the lower arm hard.
11-19-2011, 08:20 PM | #12 |
Drives: 2013 Camaro 2SS/RS 1LE Join Date: Sep 2010
Those are going to look real good!
11-19-2011, 08:58 PM | #13 |
Drives: 2SS/RS IOM CGM Stripes Join Date: May 2009
Awesome looking wheels. You definitely made a great choice.
11-19-2011, 09:02 PM | #14 |
Similar Threads | ||||
Discounts for our Military Personnel from MTI Racing | MTI Racing | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 07-07-2010 12:22 PM |
