11-01-2020, 11:20 AM | #1 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Brake Upgrade
So now the racing season is done (podium'd in class, yay) and because brakes are due anyway, I'm taking this opportunity to ugprade to C7 Z06 front hardware, stainless steel lines all the way around, the Carbotech AX6 pads all the way around.
Question is, other than calipers, rotors, pads, lines, and fluid, do I need anything else? Heat dust shields? Bolts/Clips?
My thoughts on some things:
11-01-2020, 11:29 AM | #2 |
And for braided lines I went and got a ZL1 kit which I assume will fit up correctly with the Corvette calipers. Please let me know if my assumptions are incorrect.
11-01-2020, 01:08 PM | #3 |
Drives: 02 Camaro B4C Join Date: Nov 2016
Sounds like you have most everything you need. There are several discussions on here about the conversion.
You will love the improved braking. Good luck, Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
11-01-2020, 06:49 PM | #4 |
Nick S's List on the 3rd post has all that you will need besides new caliper bolts.
https://www.camaro5.com/forums/showthread.php?p=8744227 The only issue I ran into was that the ZL1 braided lines I got did not fit through the tab that holds the line at the hard line connection. Had to drill that tab out a bit to fit it. You will wonder why you didn't do this upgrade sooner! |
11-01-2020, 08:41 PM | #5 |
The hoses I used are Goodridge, I didn't have any problems.
11-02-2020, 10:58 AM | #6 |
Thanks everyone (especially Trawz for the link to that other thread). Parts ordered and on the way.
11-02-2020, 11:09 AM | #7 | |
I went with PowerStop lines. They worked great except for being exactly the same size as the hole in the bracket. Just a quick hit with a stepped drill bit fixed that. If you can get the Goodridge lines, those are the ones to have. I compromised because I was wanting to beat the end of the racing season here. |
11-05-2020, 06:00 PM | #8 |
Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
Where did you get the calipers and rotors?
2014 Camaro 1LE SS/RS THE MISTRESS
11-06-2020, 01:14 AM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Rock Auto has good prices on the Calipers.
Orange Krush II
11-06-2020, 08:41 AM | #10 |
11-06-2020, 05:31 PM | #11 |
Wow you're not kidding that's a steal! Thanks. Time to start working on the wife on why its so important to have these. safety... ya safety.
11-11-2020, 09:12 PM | #12 | |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
Make sure you’re buying genuine parts and not counterfeit parts. Buddy originally from Detroit was telling me about a program he watched that exposed counterfeit parts for sale imported from elsewhere. Sent from my iPad using Tapatalk Pro
11-17-2020, 09:34 AM | #13 |
I got from Summit Racing - so I'm going to guess I got the good stuff.
