Old 07-02-2010, 11:01 AM   #1
Fragshunter
Drives: Black
New Era + kOOKS 1 7/8 Full 3 + TUNNING +Fuse OFF +AFM OFF....
I just have a phone call by my Tunning garage and the resoult is On L/99 Before 381 HP AFTER ALL 448 on bad condition very HOT 100 Fahrenheit ....
numbers of the test should be those , if I remeber right(phone),it's any good?
67 HP.
Fragshunter is offline   Reply With Quote
Old 07-02-2010, 11:06 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Sounds a little high, but, hey, congrats' All dynos are different, but the gains look pretty good!
'20 ZL1 Black "Fury"
Old 07-02-2010, 11:10 AM   #3
aet08
Drives: c
381HP on L99 Stock does not seem right at all.
Is that what you dyno'd to the wheels? if so, I would discount your new RWHP rating.
L99 should be less than 320hp RWHP stock.
aet08 is offline   Reply With Quote
Old 07-02-2010, 11:13 AM   #4
Fragshunter
Drives: Black
yes on wheels, I will post the graphic tomorrow when I wil ge car back.
I phone we use different unit meter...... you was right.
Old 07-02-2010, 11:17 AM   #5
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
The important number is the gain. All dyno's read different but a gain of 67HP sounds great. Even if he went to another dyno and baselined 330... he'd probably still be looking at similar 65ish hp gains on that dyno too.
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Old 07-02-2010, 11:18 AM   #6
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Seems high to me as well...heck, very few, if any LS3s are pulling 381hp stock!
Either way, the difference is a nice gain...you picked up 67 hp total with those mods!
Legend is offline   Reply With Quote
Old 07-02-2010, 11:25 AM   #7
Fragshunter
Drives: Black
in italy we use different Unit meter.... cant find a converter...
we had 448 cavalli from 381 we must convert on HP.
CV * 0.735 = kW
CV * 0.986 = HP
Old 07-02-2010, 03:05 PM   #8
SMGSS
SMGSS's Avatar
Drives: 00 SS, 67 SS
Very nice!
SMGSS is offline   Reply With Quote
Old 07-02-2010, 04:38 PM   #9
Fragshunter
Drives: Black
This is the best Porsche Tuner in Italy(Franco Alosa), this is the dyno where we the tested the camaro.
Old 07-03-2010, 01:18 PM   #10
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
Glad to see you are happy with your new era otr intake! Our kit has the coldest intake air temps out there which is best for hotter weather areas.
mike@newera is offline   Reply With Quote
Old 08-17-2010, 07:15 AM   #11
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Do you have any number on the intake temps? I live in the Cayman Islands and the normall temps around here are in the 80-90's. I noticed before but the other day when I popped the hood and touched the intake it was freaking hot from the heat in the engine compartment. Will this affect the air intake temps?
Old 08-17-2010, 09:54 AM   #12
mike@newera
Yes this is normal as engine bay components get hot due to the engine bay temps, the air traveling through it is not affected especially when you are driving (not just sitting at idle) because air is traveling through it at a higher speed. The air being sucked in with our OTR kit is coming from a completely unique location that our kit creates by tilting the radiator, which is from outside the engine bay. So, no worries. There have now been (2) independent CAI tests, and both have revealed that the New Era OTR intake system draws the coldest IAT, and also the quickest response in IAT drop to ambient once acceleration occurs.
Old 08-17-2010, 10:20 AM   #13
Indpowr
Drives: Corvette C6
When you tune out the afm how
Much gas mileage are we giving up?
Old 08-17-2010, 11:50 AM   #14
mike@newera
That is going to depend on your driving habits ultimately. But city mileage will change very little, 1 mpg if any, and highway mileage can change 1-3 mpg over the stock AFM calibration. AFM can also be calibrated to come on more often, or also only above certain vehicle speeds as well.
CAMARO 1998 RED CUSTOM MADE, LEATHER, DVD, CAMERA, NEON kachyok Autos For Sale / Wanted 0 05-23-2010 10:47 AM
Kooks Full exhaust! tples69 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 04-13-2010 08:52 PM
Kooks 1 3/4 headers - Full 3" exhaust in stock HRC V8 Bolt-Ons & Tunes 8 12-27-2009 01:19 AM
kooks developing full catback exhaust!!!! blackedout010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 05-13-2009 03:04 PM
Payment and Shipping info for 1st Edition Camaro5 shirts TAG UR IT Camaro5 Store Merchandise 154 10-18-2008 03:00 AM
