#Camaro6
Old 07-23-2019, 01:26 PM   #1
Johnkout1
Johnkout1's Avatar
Drives: 2019 ZL1 1 LE
ZL1 1LE CAMBER ADJUSTMENTS
OK Guys, On the 1LE there is a street and track setting for camber. What GM Didn't tell us is there is an additional adjustment for camber. After ruining my new 3r's on my third track day with the car I found out how to adjust the camber.
I'm an experienced driver and just got the 1LE recently.
Anyway to get to the point first you have to buy a camber adjusting bolt from the dealer.
Here is a copy of how to do it. Hope this helps everyone.
Many Thanks To Ben the Mechanic who helped me with this.
Once the camber bolt is installed loosen the two red bolts to adjust camber and then re-tighten.
You can use a long extension and go between the rotor and wheel to adjust while aligning. You can see the hole if you look above the rotor through the wheel.
Johnkout1 is offline   Reply With Quote
Old 07-23-2019, 01:35 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
This has been the same since 2010 for 5th and 6th gen camaros for front camber adjustment. Any competent alignment tech should know this. And gm defiantly has had this listed in the service manual for about 10years now.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 07-23-2019, 07:42 PM   #3
Og Neon
Lover of Speed
Drives: 2018 ZLE
Yeah I am with ICTsccaCamaro. This is standard stuff. Also the camber adjusting bolt is just a standard bolt with the matching thread pitch that threads in and pushes on the knuckle.
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 07-23-2019, 07:55 PM   #4
Hops
Hops's Avatar
Drives: 2019 1ss 1le, blue wrap
I don’t get the camber bolt, it looks like if you tighten it, you push the knuckle away from the strut for positive camber.
Hops is offline   Reply With Quote
Old 07-24-2019, 07:50 AM   #5
ICTsccaCamaro
ITCRNRS
You are correct, tighten the bolt to remove neg. camber and loose the bolt to add neg. camber.
Old 07-24-2019, 01:24 PM   #6
rickybobby
Drives: BMW M3, ZL1 1LE
You can adjust camber without that bolt. It just makes things a bit easier to dial in.
rickybobby is offline   Reply With Quote
Old 07-24-2019, 02:55 PM   #7
Tay
Drives: 1985 Oldsmobuick
Whats the part # for this bolt?
Tay is offline   Reply With Quote
Old 07-24-2019, 03:11 PM   #8
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
If you're an experienced driver, 3r's usually don't last more than 3-4 days on track. The fronts wear very quickly.... period.
Yes, front has the camber plates and the traditional strut adjustment as well. No bolts needed.
Provoste is offline   Reply With Quote
Old 07-24-2019, 08:26 PM   #9
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
On my Gen5 I use a 10mmx1.5x30mm stainless set screw on each knuckle. The thread size is the same for the Gen6. I do not know if the 30mm length would work on a Gen6. I leave mine in the knuckle with some Loctite.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
cdb95z28 is offline   Reply With Quote
Old 07-24-2019, 09:44 PM   #10
mspeed1LE
mspeed1LE's Avatar
Drives: ZL1 1LE SUMMIT WHITE
Don't forget the TTY replacements...
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________
2005 NISSAN TITAN
1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18
2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD
mspeed1LE is offline   Reply With Quote
Old 07-24-2019, 09:48 PM   #11
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
You don't need a special bolt to adjust camber on this car my man. ALSO, the 3r's cord on the inside regardless. It is NOT an alignment issue. I'm starting to think there is some toe adjustment under load or something that destroys the tires. unfortunately, if you track this car get used to replacing tires. I only get 6-7 sessions per front set.
seanblurr is offline   Reply With Quote
Old 07-25-2019, 04:56 AM   #12
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Or maybe it's just a heavy car and under corning load there's just a lot of load on the front outside tire. But what do I know, I don't track my vert.
Can't wait to see all the new c8 owners bitch about how fast there new cars eat back tires with the rear weight bias. <3 sec 0-60 comes at a price.
Gunkk is offline   Reply With Quote
Old 07-25-2019, 06:39 AM   #13
mt.nichols
Drives: '19 ZL1 1LE
This. I've tried three different alignment settings and the tire wear is virtually unchanged.
Big, heavy car with a lot of weight on the nose - I guess it is to be expected.
mt.nichols is offline   Reply With Quote
Old 05-11-2024, 10:07 AM   #14
AMICHIGANBZL11LE
Drives: 23 ZL1 1LE
Camber adjusting bolt part number?
Hi wondering the part number for a zl11le camber adjusting bolt?
Thank you.
Black zl11le
AMICHIGANBZL11LE is offline   Reply With Quote
