11-13-2011, 02:38 PM | #1 |
Drives: 2011 2SS L99, 2010 LT RS Join Date: Mar 2010
Vararam: change red coupler hose
There are two things which I realy don't like about the red coupler hose of my new Vararam:
- It is red - The nipple which is simply sticked into the red coupler hose Sticked into the red rubber coupler the nipple doesnt get a lot of support. Because the engine is moving while the Vararam intake is fixed the red coupler hose is in permanent action. At the same time the PVC line hose is pulling on this nipple. I already installed a cable strap to the nipple from the inside of the red coupler hose to make shure it wont go anywhere. The second problem I am not shure about is the fact that the nipple reaches quite far into the coupler hose and has a affect on the air stream. I mean a lot of us are buying stuff like Vmax porte TB or Fast intakes to improve airflow. At the same time we plug a 1 1/2 inch long nipple right in front of the TB inlet.... this make sense to me. So I would basically like to change this nipple for something else or remove it completely. .... oh and at the same time I'd like to swap the red coupler hose for a black one. Any ideas and recommendations are welcome. . |
11-13-2011, 02:51 PM | #2 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
11-13-2011, 03:28 PM | #3 |
Invisicord Products
Drives: 2016 Camaro SS Join Date: Sep 2011
You could get an RX breather and eliminate the hose completely. You would cap off that nipple, and the other end as well.
11-13-2011, 03:36 PM | #4 |
11-13-2011, 04:43 PM | #5 |
Does anyone knows if the stock coupler hoes could be reused on the vararam? (Don't have mine here to check)
11-13-2011, 06:34 PM | #6 |
Drives: 2010 ss. 1990 RS the faster one. Join Date: Jan 2011
I'm sorry but you should learn to over look this. Go to track and actually race your car or send the vararam back and buy something else. You bought the Vararam because you are a well informed consumer and research showed the this will provide a significant improvement over stock right? So........
11-13-2011, 07:32 PM | #7 |
RIP - Convertible SS
Drives: '13 Mustang Boss 302 - RED Join Date: Apr 2011
I'm looking to do the same. Anyone know what type of hose this is......what it's called...where to get it?
11-14-2011, 09:26 AM | #8 |
Drives: 2010 2ssrs Join Date: Nov 2010
4 inch hose
I replaced mine with a blue piece,I purchased it at Amazon Hose andRubber here in Miami.It is a silicone hose the we use in marine exhaust systems.I am sure there are cheaper options but this stuff is really tuff.
11-14-2011, 01:30 PM | #9 |
So I'll need a black 4inch hose to replace the red one and a RX breather to get the huge nipple out of my intake channel. Sounds like a plan.
Any downside of the RX breather v.s. the PVC hose connected directly to the intake manifold? |
11-14-2011, 01:42 PM | #10 |
Invisicord Products
From what I have been told you need a 4" ID hose/coupler that is 2" long. Just so you know the dimensions of a replacement coupler.
11-14-2011, 01:45 PM | #11 | |
Ted.
www.jannettyracing.com
11-14-2011, 01:49 PM | #12 |
Invisicord Products
If he is putting on the RX breather, then there should be no hole needed in that coupler, just need to cap off the other end where that hose would have gone, then install the breather in lieu of the oil fill cap. At least this is how I understand the installation of the breather.
11-14-2011, 03:00 PM | #13 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
I replaced mine with a black one. Then I drilled a hole in the box itself and fastened a hose nipple and slid the hose on
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
11-14-2011, 03:08 PM | #14 |
Invisicord Products
I don't think that is a good idea. This means you are now introducing oil upstream of the MAF? There isn't really any good place to introduce the oil/air line so that it is past the MAF except on that coupler. If I were keeping the factory crankcase line, I would still keep the hose running to the coupler, but would try to relocate it on a different side than top center.
Similar Threads | ||||
GM Heritage Collection - sale | Moose | 5th Gen Camaro SS LS LT General Discussions | 65 | 06-27-2013 02:28 PM |
VARARAM | 2010+ 6.2L V8 Camaro Ram Air Intake - Tune & No Tune Required Systems! | AutoAgenda | V8 Bolt-Ons & Tunes | 29 | 03-12-2013 06:51 PM |
2010+ 6.2L V8 Camaro Vararam Ram Air Intake - Tune & No Tune Required Systems! | AutoAgenda | V8 Bolt-Ons & Tunes | 20 | 10-29-2011 10:25 PM |
Stupid to change RED SS decal - yes or no | Sstac | Cosmetics and Lighting Modification Discussions | 26 | 10-17-2009 05:37 PM |
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over | bigralph | Off-topic Discussions | 15 | 02-06-2009 07:07 PM |
