01-05-2012, 09:24 PM | #141 | |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
Do you have a 2012? The previous comments were about the mirror wiring being different than the 2010-11s. I have an invisacord in my 2010...easy install. I didn't have to file anything down.
NY5thgen.com
01-06-2012, 08:38 AM | #142 | |
Drives: 2012 2SS Camaro 45th Anniv Convert. Join Date: Oct 2011
However, the LEDs on the V-1 do not appear to be as bright as before. Wondering if I need to switch the fuses in the add-a-circuit or I'm not getting enough power to the V-1. I do not have a multi-meter.
2012 2SS, RS 45th Anniversary Convertible
K&N CAI Flowmaster Axel Back Hurst Short Shifter ThePowderPros Ported TB JL XD700/5 Amp, Focal sub, Polk Speakers and ******** stuff. 2011 Mercedes C-300 (Wife's car) http://s115.photobucket.com/home/ncbob |
01-22-2012, 08:44 AM | #143 |
Drives: ELLE-1 Join Date: Jul 2011
which spare fuse is hot??
01-22-2012, 02:32 PM | #144 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
This is where most of us have tapped into.....this way when you turn on your car, and if you leave your radar detector or whatever on.....it will come on when you start it, and go off when you turn it off. on the fuse panel on the left side of the dash.....their are two fuses labled as POWER OUTLET #1 (Fuse F17) and POWER OUTLET #2 (Fuse F18)....this is for 2010 and 2011's....the 2012's could be different. both are 20 amp fuses.
02-07-2012, 05:02 PM | #145 |
Drives: 2011 Camaro 2SS/RS Vert Join Date: Jul 2011
When I went to hard wire mine into the fuse panel the fuse that says display apprears to turn off when the car turns off but it doesnt. Anyone know any of the fuses that will turn OFFF when the car does?
02-07-2012, 05:09 PM | #146 | |
02-07-2012, 07:03 PM | #147 |
Drives: Hearse Join Date: Nov 2011
i just now completed mine hooked the power up to th pink wire located on the airbag/pasenger seat notification light. only on when key is on checked everything works great.
ground i just scraped paint off under bezel with self drilling screw but use caution pick the right spot so you wont go through the roof |
02-07-2012, 10:47 PM | #148 |
yes you can.......but I would replace it with a 3 or 5 amp.......actually about all you need is a 2 amp.
02-08-2012, 10:35 AM | #149 |
Im still waiting for the answer to the 2012 Camaro installation of the rear view mirror DIY... has anyone figured out how to get switched power from the 2012 rear view mirror? I want to use an invisicord...
2017 2SS Camaro - M6 - Hyper Blue Metallic - White Pearl Rally Stripes - Khalari Interior - Khalari Knee Pads - NPP - Sunroof -
02-08-2012, 06:18 PM | #150 | |
i used the pink wire that goes up unto the overhead bezel another post stated the same pink wire in the rearview mirror plastic bezel works |
02-09-2012, 08:35 AM | #151 |
do both of those options give you switched power?
02-27-2012, 10:21 PM | #152 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
Tag
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
02-27-2012, 10:39 PM | #153 |
Tag? What is that?
02-27-2012, 11:00 PM | #154 |
It's a way to mark a post that has good info to find it later when I search my posts.
Similar Threads | ||||
My JL 12" and JL 250 amp install VIDEO AND PIX! | TAG UR IT | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 55 | 02-12-2011 01:03 AM |
DIY Rally Stripe Graphic Installation Tips (wet install) | SUPERSPORTED | Camaro DIY & HOW-TO instructions & discussions | 26 | 10-11-2010 02:36 AM |
Hardwire Radar Detector? | mhennick | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 10 | 06-13-2009 10:27 PM |
Radar detection systems? | DGordon | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 68 | 04-02-2009 09:05 PM |
radar and laser detector and jammers | Az Sparky | Off-topic Discussions | 49 | 08-27-2007 10:03 PM |
