Old 11-15-2016, 10:09 AM   #1
SSyclone
SSyclone's Avatar
Drives: 2011 2SS Inferno Orange
LSA tuning day TODAY
The last two months have been a lot of work on my 2011 Camaro SS.
Started with the 3:91 gear swap, and urethane sub frame bushings. Swapping out the SS pump for a ZL1 unit at the same time, along with a ADM FPCM. Once done I tested that a couple of times and began installing my LSA conversion. I bought the used ADM kit from another C5 member. Adding some ID 850s and wire harness extensions from ADM along the way.
I've been in no hurry, I work a lot of hours but she's finally all ready and a Tuner by the name of Shane Hinds is on his way out to put the finishing touches that I just can't do to her. It should be a great day!!!
2011 Camaro SS
Buckets of money under hood!
SSyclone is offline   Reply With Quote
Old 11-15-2016, 10:36 AM   #2
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
Whew! LSA + 3.91 = increase your tire fund.
Good luck. She will be a beast. Shane has these things figured out.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
wrtowman is offline   Reply With Quote
Old 11-15-2016, 12:55 PM   #3
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
3.91's with this blower make for a lot of fun. But unless you have a drag radial, it's like driving on ice the second you give it even the smallest amount of throttle hah
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 11-15-2016, 01:09 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
So true, that's why I have 3:45s now..
-Don
747 RWHP 794 RWTQ
Old 11-15-2016, 01:43 PM   #5
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
That's why I never changed the gears in the rear.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 11-15-2016, 03:53 PM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I foresee a gear change in his future.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 11-15-2016, 05:14 PM   #7
SSyclone
SSyclone's Avatar
Well it runs like an absolute beast, the clutch however is the first victim!
My plan was clutch and driveshaft over the winter, then drag radial NT05 or the like. Axle shafts if needed. However It appears the clutch will require immediate attention.
2011 Camaro SS
Old 11-15-2016, 07:20 PM   #8
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
not to hijack the thread but has anyone gone from 3.91 to 3.45 for blower use?
supergt99 is offline   Reply With Quote
Old 11-15-2016, 07:34 PM   #9
wrtowman
wrtowman's Avatar
I believe Hammdo had 3.91s at one time and went to 3.45s.
Old 11-15-2016, 08:41 PM   #10
hammdo
hammdo's Avatar
Yep, sure did, 3.91s with my A6 was just too much. Drove it a week that way and just crazy. 1st and 2nd were really useless, just give it a bit too much gas and spin city. Cloud of smoke is cool, but those damn tires cost too much. Even with drag radials, my combo was just too much. Some may do good with it, but ADM and just about every one else said 3:45s. That's what I did, and I'm glad...
Still get 20+ mpg, if I stay out of the gas...
-Don
747 RWHP 794 RWTQ
Old 11-15-2016, 11:32 PM   #11
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
-Don
Yeah I can still get 22-24mpg on 91 on the freeway.
16-17mpg on E85
Love this setup. Rips through the gears when I want to.
Old 11-16-2016, 09:03 AM   #12
1KillerSS
1KillerSS's Avatar
I went from 345 to 323's love it. I also get 20mpg on the highway at 80mph.
Build thread
Old 11-16-2016, 12:03 PM   #13
jose1003
jose1003's Avatar
Drives: 2010 Camaro 2SS Cyber Gray
on mileage I get 15-16 combined is this about right?
jose1003 is offline   Reply With Quote
Old 11-17-2016, 06:55 PM   #14
hammdo
hammdo's Avatar
Yep, pretty close. City/highway combined.
-Don
747 RWHP 794 RWTQ
