#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V6 LGX Engine, Exhaust, and Bolt-Ons
Old 09-26-2016, 07:24 AM   #1
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS
2016 V6 Automatic with NPP - Dyno Results
Tried searching but it looks like Phastek is the only other thread with a dyno result. I organized a dyno day this past weekend and we had a wide assortment of cars on the dyno. I threw my 2016 v6 on the dyno and was pretty happy with the results.
277rwhp! Not too shabby considering it's going through an 8 speed automatic.
Will update with graph later. I don't remember torque, but I was pretty surprised to see the 2016 v6 automatic dyno'd exactly the same rwhp as my previously owned 2014 v6 6-speed manual. So the difference in RWHP from 2014 to 2016 is about equivalent to the horsepower loss you'd typically see between automatic to manual transmissions.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2016 Camaro 1LT A8 - "Elmo"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 09-26-2016, 07:32 AM   #2
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
This looks legit.
MiamiBlueCamaro is offline   Reply With Quote
Old 09-26-2016, 07:45 AM   #3
meissen
meissen's Avatar
Figured the post was kinda useless without the graph so I ran out to my car to take a photo.
Old 09-26-2016, 07:51 AM   #4
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Good stuff. I remember phastek was having problems topping out or something so they only netted about 240ish. They figured it was about 25-35 lower than what it should be. Good to see someone got it done.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 09-26-2016, 07:52 AM   #5
meissen
meissen's Avatar
The person running the dyno was well familiar with my 2012 and 2014 Camaros that were both v6 6-speeds and had to be ran in 3rd gear to avoid topping out on MPH.
If my memory serves correctly, he said he kept it in 5th gear for the runs so he would avoid hitting the speed limiter.
Old 09-26-2016, 09:27 AM   #6
Weedo
Drives: 2016 Camaro RS
I think i confused myself... The 277hp is for your 2016? Or 2014?
Weedo is offline   Reply With Quote
Old 09-26-2016, 09:33 AM   #7
meissen
meissen's Avatar
This is on a 2016 Camaro v6 8speed automatic with NPP. It made the exact same rwhp numbers as my v6 6-speed manual 5th gens.
Edit: I have to update my signature - I traded my 2014 Camaro in for a 2016 back in June
Edit Edit: I just realized the OP said "2014" where it should have said 2016. Sorry for the confusion.
Old 09-26-2016, 09:42 AM   #8
Weedo
I have to update my signature - I traded my 2014 Camaro in for a 2016 back in June,
Interesting! Ok, so a bit low then based on the 335hp (vs the older Gen with less power). I suppose the 0-60 (5.1) and quarter mile significant drops are more because of the lower weight (200-250lbs?) and "better" gearing, than the horse power and torque increases.
Old 12-01-2021, 02:59 PM   #9
Enriquez
Drives: Camaro LS 2018
Camaro6
This is what I got on my Camaro 2018 V6 with realdash Name:  IMG_20211201_015327439_HDR.jpg
Enriquez is offline   Reply With Quote
Old 12-01-2021, 05:42 PM   #10
versionx
Drives: 2019 Camaro 1LT 3.6 v6
What is the numbers before the tune?
versionx is offline   Reply With Quote
