05-17-2024, 06:12 PM | #1 |
Drives: 2017 ZL1 Join Date: Aug 2020
Recipe for 1000 rwhp and cost?
I might b getting a newer ZL1 and start from scratch
05-17-2024, 08:29 PM | #2 |
Drives: ZL1 1LE, bolt, scary flatbed, hhr, Join Date: Apr 2023
this will be fun to read - and I'm sure big money to get to that 4 digit number.
The Yenkos are pricey and their latest 24 model is stated to make 1,500 crank hp. Amazing thing to me is chevy will warranty the car |
05-17-2024, 09:17 PM | #3 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Heads, cam, 2650, big gulp, 112TB, port plates, fuel system, e85, 2" headers, 3" mid section Boom. 1krwhp.
20k in parts plus probably 15 or 20 in labor and tuning.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-17-2024, 09:28 PM | #4 |
Can one get there using the stock sc, aftermarket lid and Kong x port and all the other associated mods?
05-17-2024, 09:36 PM | #5 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
FYI at 1K WHP the LT4 short block is on borrowed time…. Crank is fine but the LT4 “forged” pistons & rods should be upgraded.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
05-17-2024, 11:19 PM | #6 |
fo'shizZL1
Katech says the stock stuff with main studs, rod bolts, and good bearings will handle 1000 easily. I'd upgrade the thrust bearing, too.
05-17-2024, 11:28 PM | #7 |
Drives: 2022 Camaro ZL1 Join Date: Sep 2023
RPM stage 5 should get you there. Or multiply this 2x if you go through vengeance or LMR in tx.
05-18-2024, 08:04 AM | #8 |
LT4 rods have been pulled at that level and were bending. Aftermarket options are superior… if you’re going to pull it apart for a proper thrust bearing and main studs, it’s insane to reuse pistons & rods at the end of their capacity.
05-18-2024, 08:23 AM | #9 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Built motor, 416ci, Whipple 3.0, All the fuel mods + port setup, E85, Drag Pack, and then start saving to build the transmission.
GM Gen V Calibrator
05-18-2024, 08:49 AM | #10 |
Drives: '20 ZLE Join Date: Jun 2020
I kept the stock SB, and made 1000+ with heads, valve train, E2650, FBO, 100 oct. and OEM hpfp, but the SB began to fail.
I didn't see your budget. There are a bunch of ways to get there the simplest and least stressful way perhaps would be an LME 427 with 2650, FBO, etc. The cost driver in the discussion is, you should upgrade your entire long block and transmission.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
05-18-2024, 11:42 AM | #11 |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
My C7Z is new stock rods at the time with diamond pistons. I told LPE what I wanted to do and they said it would be fine. Sees 14psi at 3krpm and 24 degrees of timing by 3,500rpm. Peaks at 17.5psi and 26 degrees of timing.10k miles later she still rocking. Tune is dialed and is only DI only though. Loading the cylinder with meth or port injection AFR’s I’m sure wouldn’t help matters.
05-18-2024, 12:09 PM | #12 | |
'20 ZL1 1LE A10.
05-18-2024, 12:25 PM | #13 |
fo'shizZL1
Interesting. I didn't realize that. I thought Katech had pushed them on the engine dyno to 1500 or so before they started to see rods bend. No doubt the aftermarket is better, just figured if it's good to 1500 crank or so, why bother. But if it's not, it certainly makes sense to upgrade.
05-18-2024, 02:16 PM | #14 | |
